i need to adjust this all 4 are in different postion. in the throat of the carb there is a little pin sticking out again all 4 postioned different. this is the first time i have done carb work myself thanks for any help here
idle mixture screw
Adjusting fuel/air can be done by "ear", with a tach or color tune.
But first would check that the pin sticking out will go up/down when turning screw. If not pin on end of screw has broken off and will need to be R & R.
Start with all four pilot screws 1 1/4 turns out.
vac sync carbs
set RPM as low as it will idle smoothly with main adjustment on carbs. Turn pilot screw slowly out on one carb. Listen for change in RPM. Continue turning until either RPM peaks or idle becomes "ruff". Note how far you've turned pilot screw. Now turn it other direction and keep track of turns same as above. Best spot for screw will be middle of number of turns between the two.
Should check vac sync agin and then go to next carb etc....
mro
btw
leaking cam chain tensioner plug on my other 80G. Pulled out plug, smeared it with non-harding gasket sealer and put back in. Not leaked since.Last edited by mro; 11-11-2006, 10:29 AM.
