transmission shift problems-newbie
  • ricks1100
    • Nov 2006
    • 14
    • Campbell, CA
    i just got a 1978 xs1100
    major problem is that its stuck in first gear
    the clutch seems to work cause i pull it in and the wheel stops spinning on the center stand.
    new to these bikes.
    the shifter does spring back when pushed
    but no change is felt on the tranny
    help i wanna ride!
    bike was sitting for a while but starts up fine and runs smooth otherwise.
    thanks
    rick
  • randy
    • Dec 2003
    • 4521
    ricks1100;
    You may have a broken shift lever or the pins on the shift drum fell out. Either way you'll need to remove the shift cover to investigate.
    • mro
      • 4276
      • Hayward, California
      Check shift shaft alignment.
      Have checked several and have NOT found em out of adjustment. Could be your problem but most likely as randy says.
      mro
      btw
      welcome to XSland
      • ricks1100
        • Nov 2006
        • 14
        • Campbell, CA
        shift problems
        i took off the shifter cover
        and found that the sector gear
        attached to the shift shaft cracked and laying in the cover.
        i still can't get the bike into nuetral
        if i move the other gear it only shifts to three locations one down and two up if i hold the clutch in and crank to kick starter the rear wheel moves.
        i don't know if changing the shift shaft gear/
        shift shaft and bolting it back together will fix the problem or will i have to dig into the tranny. the bike ran fine about 6 months ago
        then when started about a month ago
        the shifter broke. if i bolt everything back together do you think the bike just needs to be running to change gears easily or is ther another problem
        thanks any info will help
        rick
        • Goin Commando
          • Sep 2006
          • 125
          • Florida
          With the bike on the center stand, can you turn the shift drum if you move/rotate the rear wheel by hand?
          I love the smell of Napalm in the morning.... It smells like......victory
          • ricks1100
            • Nov 2006
            • 14
            • Campbell, CA
            shifter
            yeah i can turn the drum its pretty stiff though
            do these bikes not like to shift when cold?
            i have to pul in the clutch lever and there is a lot of tension on the rear wheel. do you think the clutch needs adjustment?
            • Goin Commando
              • Sep 2006
              • 125
              • Florida
              I know that they dont like to shift very easy while not running. And yes there will be some drag while rotating the rear wheel, in gear, while holding in the clutch.
                Hey Ricks,
                How about editting your profile and listing WHERE you are, there are plenty of us all around the country, you might be able to find a fellow Xsive in your neighborhood that could provide some on hand assistance, someone who knows what these machines feel like, etc.?!
