I need an XS expert!
  • Deano62
    • 20
    • South San Francisco, CA
    I have several issues with my '79 XS Eleven. I could use some input.
    1. The bike has a Yamaha faring, hard bags, and trunk which I assume were stock when the bike was first sold. Problem is, on slow turns the front end wobbles like crazy. Is is just because of the weight of the faring? I've had the fork oil and seals replaced. The mechanic couldn't explain the instability of the bike.
    Any ideas?
    2. About a year ago I had to replace the front brake calipers. I couldn't find ANY new ones and my local dealer won't touch a bike this old. I ended up with two left side calipers off of ebay so one is on upside down, causing stress on the right side brake line. The pistons in the old caliper were too pitted for clean-up or machining.
    Is there a supplier anywhere in the U.S. that has new or remanufactured calipers for a '79?
    3. I want to paint the tank, faring, bags, and trunk but can't seem to match the original color. It is faded after all these years. Does anyone know the original color code? The tank is a metalic blue-green. The faring and bags are just weathered greenish.
    Thanks for any help.
    If it won't go, force it. If it breaks, it needed fixing anyway.
  • prometheus578
    XS-XJ Super Guru (RESIGNED)
    • Aug 2004
    • 4012
    • Olympia , Wa.
    Any time the front end is off the ground, the steering bearings should be checked. I mean something as simple as grabbing the forks and shaking them to see if they're loose, or turning the bars and feeling if the bearings are 'notched'. That's one solution.
    Are the tires cupped? Running your palm over the tread... should be relatively smooth, no noticeable ridges from tread cleat to tread cleat.
    Caliper pistons just need to be smooth, not perfect. Unless they're badly gouged some how, should be possable to lightly sand the rough spots so they slide nicely.
    Take and use the pistons from the new cylinders in the old calipers.
    • Deano62
      • 20
      My mechanic checked the bearings when he replaced the seals. The tires only have a couple hundred miles on them and air pressure has been checked regularly.
      As for the caliper pistons, the old ones were froze up so bad no amount of hammering could free them. (footnote: they froze up on a gravel driveway. Imagine my surprise when the bike when "plop". lol)
      Thanks for the tips though.
      • oseaghdha
        • 1075
        • N43.02.5,W88.14.2
        Sounds like side flex. Maybe a fork brace would help?
        There is a pair of calipers on E-bah right now for $60.
        You probably won't find any new ones out there.
        You will likely need to have the paint matched. Lots of paint houses can do this.
        Ditch the mechanic: DIY.
        XS1100SF
        XS1100F
        • randy
          • Dec 2003
          • 4521
          Deano62,
          New caliper pistons are available from Mike's XS
          • xschop
            • Feb 2006
            • 1794
            • oklahoma city
            wobble
            double check your wheel bearings, could be fried...chop
            MDRNF
            79F.....Not Stock
            • randy
              • Dec 2003
              • 4521
              Mikes XS caliper piston # 29-0516 will fit XS11 standard '79 front and rear. $24.00 each
              • MAXIMAN
                • Jan 2005
                • 1817
                After my 4000 mile road trip to Tahoe Zilla developed a little wobble too. When I got it back in the shop I foudn the steering head bearings needed to be tightened. Once I did that it went away.
                • jimboreeno
                  • 427
                  • Smithville, MO
                  I know this sounds too simple but make sure your front axle bolt is tight. Even a quarter turn loose will create a wobble. Test by backing up and turning, if there is caliper drag check the bolt.
                  I lived with this on my XJ after a shop put on new tires. I thought I had a bad tire till I checked the bolt.
                  JimBoReeno
                  My Ex!"Half-Breed"
                  '82 XJ1100 Maxim with
                  '80 XS1100SG Motor
                  Current Bike
                  2000 Indian Chief
                  Millennium Edition
                  • MRR046
                    • Nov 2006
                    • 7
                    • Chattanooga, TN
                    calipers
                    I just ordered rebuild kits and was quoted 238.00 dollars for new calipers (I think from Parts Unlimited) so new calipers are out there but damn expensive. I have seen several used calipers on Ebay as well.
                    MRR
                    Two 79 XS1100SF
                    87 Suzuki GSX-R1100
                    84 Honda Sabre V65 1100S
                    86 Honda Shadow VT500C (wife rides this one)
                    • LoHo
                      • Sep 2002
                      • 1342
                      • Fresno, CA
                      Deano, I just bought a right caliper from eBay which i may not need, if my repair onthe old one works. Ping me a PM if you are interested. I'll meet you halfway...
                        Hmmm.. I've never seen a break caliper piston so froze up that a big "C" clamp and brake presure working it back and forth wouldn't work out. I have been shot in the chest with a piston and brake fluid when it did come out though! lol.
                        My front brake also locked up in a gravel drive and went "Plop". It's a sickening sound if I do say so!
                        PM Andreaswise... I'm sure he's probably got SEVERAL.
                        • SFerinTEXAS
                          • Jun 2006
                          • 877
                          calipers
                          maybe too late to help but i learned a good trick for frozen calipers. use a too big nut as a spacer, use the banjo bolt and washers to plug the fluid port with the too big nut where the banjo fitting was, then open the bleeder a little and put a grease gun right on the bleeder and it should pump that piston right out.I used that trick on a caliper that was locked hard and all else failed till a friend suggested this to me.
                          79SF
                          XJ11
                          78E
                          • webbcraft2150
                            • Sep 2002
                            • 1605
                            • AUSTIN.TX
                            Fairing "n" stuff should not cause a wobble. Since the fork tubes were off for the seal job, check All the bolts nuts, ect. Make sure your forks are "aligned". As you might tell, no one here has much nice to say about taking an old XS to a shop. There are a few "independant" shops that specialize in old iron and can do a good job. Most of the "big" shops can't and/or won't work on them, and if they do, things come back worse. Can't blame em though, most of techs are dialed in on the late model stuff, most of the techs work on flat rate and don't see much money in working on something they are not familiar with.
                            My last wobble session showed up chasing Hippie Dave, damn those OEM shocks.
                            • Geezer
                              • May 2003
                              • 2985
                              • Willamina, Oregon 97229
                              Change the fork oil. If it smells bad, has water in it, or is dark colored. Take the forks apart and clean them before refilling. This also would be a good idea to install new for seals.
                              Geezer
