LED's
  • red bandit
    • 970
    • central michigan
    LED's
    OK, I've decided to bite the bullet and buy LED light's. Witch one's do you suggest for the brake light's and witch one's for the running/turn signals in the fairing, and how about the running light's on the crash bars. Narrow or wide angle? 12, 19, 24, or 30 led's per bulb? On the rear I have the original tail/brake plus 2 tail/brake on the trunk. The rear turn are turn only, I was going to leave them regular bulbs so they would make the turn signal flasher work. How's this sound? What do you guys have/think/suggest?
    Red Bandit
    79 SF parts bike.
    Okay Red,
    You asked for it!
    Have you checked out the different sections of the Superbrightleds.com site?
    I don't know about the Crash Bar "Running Lights" if you are talking about Aux Driving Lights, almost any pair of 55 watt halogens will provide a boost to your view, I got the Pilot brand from Walmart with ~4" round lenses, but there are many designs, ovals, etc.!
    You have the 79F, but the Fiche site shows the double bulb wide design, but some of the photos on our site show the small single bulb housing, depending on which one you have will also contribute to which type of bulb you use!
    1157 separate bulb base/circuit board:
    1157-PCB-R36 Red LED lamp
    12VDC 1157 Base (dual intensity) with 1-1/2 square LED cluster
    36 Red LED lamp; it's only $9.95, but the display size isn't very big!
    Another option is the complete bulb. But again, the size of the bulb is not very large, even with the radially aimed leds and wide angle bulbs. $7.29
    1157-R24 Red LED bulb Super Red 24-LED 12VDC replacement bulb
    15mm Dual Intensity Bayonet Base
    Unique Design has 18 LEDs aiming out the end and 6 radially mounted
    Below would be suggested for the small single bulb housing.
    This is the TRUCK light, it's 4.3" diameter so the 61 leds are displayed over a larger area in the rear tail light housing, but you'll need to get the PIGTAIL plug with it to wire it in.
    ST-R61 Truck Light - Red LED
    Truck Stop/Tail/Turn Light with 61 Super RED LEDs
    12 VDC, Four inches diameter DOT SAE Approved
    Grommet, Flange and Plug sold separately below
    $ 24.95
    Below is what I used for my dual bulb wider housing:
    PT-R56 Truck Light - Red LED
    Truck Stop/Tail/Turn Light with 56 Super RED LEDs
    12 VDC, measures 6.5 x 2 inches
    DOT SAE Approved
    $ 19.95
    PL-3R Plug
    Low Profile Right Angle 3-PIN Plug with 10 inch wires
    For ST and PT series Truck Lights $ 1.49
    As for your TRUNK LIGHTS, not sure how the bulb socket and bulb is positioned in them, so you'll have to determine which type will give best display and FIT!
    The rear turn signal could use this one, but again, not a big display area, but I keep forgetting you have the Standard, a bit narrower housing vs. the Special's ROUND!
    1156-PCB-Axx Amber LED Lamp = $7.49
    12VDC 1156 Base with 1-1/2 inch square circuit board
    With 24 or 36(+ $2.50) Super Amber LEDs
    Another option:
    Right Angle 30 LED bulb
    30-LED 12VDC replacement bulb
    15mm Single Intensity 1156 or Dual Intensity 1157 Bayonet Base
    35 Degree Viewing angle LEDs are aimed 90 degrees from the base
    1.92" long from contact to top of LED housing, LED housing is 1" diam. x 1.25" long
    Select Bulb type and LED Color
    $ 9.95
    Front Running/turn signal in Fairing:
    1157-PCB-W36 White LED Lamp **EXPENSIVE** due to WHITE $19.95
    36 White LED lamp
    Other Option, complete bulb: Not sure how much room in fairing or position of socket and OEM bulb?
    1157-A24 Amber LED bulb only $7.29 ea, select wide angle.
    Super Amber 24-LED 12VDC replacement bulb
    Go ALL LED, and get an electronic flasher, either this one:
    LED bulb Flasher Unit
    Electronic LED Flashers have no minimum load, 12VDC Select one of 7 types, see descriptions on our Tail/Turn/Brake bulb page $ 12.95
    OR a 2 prong one from local auto store, Trident brand was one I found and used, was combo electro-mechanical but NOT THERMAL, has worked just fine, was about $8.00.
