Removing decals from plastic
  • Incubus
    • 1003
    • Austin TX
    So I'm to the paint now. Don't get me started about the prep. The PO was an idiot. Used maybe pickup bed liner black evil stuff over the original paint on the tank. It's been fun.
    That, however, is not my question. My plastic side cover and my Vetter trunk and fairing have decals on them. The decals must go. They are long past the point where anyone could even them even get into the same zip code as decent. I could scrape them off, but I likely will end up scraping the plastic and/or fiberglass and wishing I still had decals.
    What's a good way to gently remove ancient decals? I tried mineral spirits. They laughed. I tried acetone. They seemed to feed on it and grow larger and even more grungy. At this point, not only must they be removed, but they must be made to suffer for the indignities they have imposed on me. Their epitaph will be written in flame.
    I'm OK. Really.
    Anyway, thanks, y'all.
    Patrick
    XS11F (Incubus, daily rider)
    1969 Yamaha DT1B
  • xschop
    • Feb 2006
    • 1794
    • oklahoma city
    good ol' gas
    I like 93 octane myself. just did an entire z-28 decal from hood to trunk...chop
    MDRNF
    79F.....Not Stock
    • Incubus
      • 1003
      • Austin TX
      Gas. Very effective. And it made lighting the shards that much easier....
      1969 Yamaha DT1B
      • prometheus578
        XS-XJ Super Guru (RESIGNED)
        • Aug 2004
        • 4012
        • Olympia , Wa.
        WD 40... also heat it up with a hair dryer to weaken the adhesive
        • Ljay40
          • Jun 2006
          • 149
          I used a propane torch and a sharp razor knife just waving heat over the decal oh so slightly as not to burn it just to heat the glue then used razor knife
          to peel off decal as I heated it worked pretty good once you got the decal started What ever you do Dont use an air
          sander on the fairing sand the glue lines bye hand with 400 grit then go to six hundred. I got lazy and used air sander and you can see the swirling patterns some where I painted it after.
          The side I did by hand looks lot better.
          Cheers
            Like Prom, I would use an electric heat gun. It doesn't take much heat and I would be worried about scorching something with an open flame from a torch.
              I have heard of using fishing line rather than a razor knife. Keep that acetone away from paint and plastics!
