pggg, I made some good progress on the R1 front end this weekend. Spray welded up the steering stem and ground to 1.193" for a perfect press into the R1 lower clamp. New bearings, and an upper bushing to fill out the top R1 clamp because the bearings are diffferent on the top, 25mm for the XS11 and 30mm for the R1. New seals for the fork legs now I have to build the forks, I may shim the R1 springs for a bit more stiffness, on a budget you know? I have the wheel/tire/rotors/axle, calipers, and fender. I'll need s/s lines and a way to run the speedo. Oh yeah, also bored the top clamp to accept the tubular handlebars, I'll use XS650 risers. Getting there.
Cheers, 50gary
Cheers, 50gary
