Steering tapered bearings
  • Incubus
    • 1003
    • Austin TX
    Tomorrow I take apart the triple tree because the steering on this old XS1100F is stiff. It could be the grease has just hardened up from 15 years of inactivity. It could be the bearings are toast. In order for me to know how careful I have to be, I need to know the price of carelessness before I start. Does anyone know a good source for these bearings? I'm looking for something reasonable, but at the same time of sufficient quality to last as long as the originals. A 27-year warranty would be very cool.
    I would be very nice to find bearing part numbers that I could use to call the local bearing house, if needed. Does anybody know the generic number for these bearings?
    Thanks
    Patrick
    XS11F (Incubus, daily rider)
    1969 Yamaha DT1B
    Bearing supply place can cross them to what you need.....
    • 50gary
      • Apr 2006
      • 225
      • Saginaw, Michigan. USA Third stone from the sun
      XS11 upper steering head bearing part #HR32005XJ
      25mm bore x 47 mm OD x 15mm ht
      XS11 lower steering head bearing part #HR32006XJ
      30mm bore x 55 mmOD x17mm ht
      This is from a local bearing house in my town listing is for tapered roller bearing in metric sizes.
      These are NOT Yamaha part numbers.
      The #s on the actual bearings I took out are upper #32005JR
      lower #32006JR
      I'm just now working on adapting an R1 front end to my XS11E
      it might work?
      Cheers, 50gary
      • Erik the Red
        • 422
        • Northern MI
        I got my bearings from Zanotti's (http://www.zanottimotor.com/) and if I remember correctly, upper and lower bearings were around 25 bucks apiece. If you do get them from here, they're not pre-greased, so you'll have to do that yourself.
        After painstakingly tapping in the upper into the tube, I decided not to mess with the one on the triple tree stem. Totally worth the 10 bucks to have a shop use their hydraulic press.
        -Do what makes you happy.
        '79 Honda CB 750 K (2)
        '78 XS 11 E - "Rhona"
        ...and a 2nd E, for the goodies on it.
        • Snow
          • Oct 2002
          • 1041
          • Tallahassee, FL
          +1 for the hydraulic press. I spent maybe an hour trying to get that one stupid bearing off before conceeding that it was pressed on... Do yourself a favor and have a shop press off the old one and press on the new one.
          Also, make sure you have a drift pin or something that you can use to take out the bearing race from the frame side.
          And of course, everyone's favorite trick for installing bearing races - put the new race in your freezer for a bit to shrink it
          If for some reason you can't find the correct bearings in town (doubtful), you can get them from partsnmore.com - everybody's *favorite* Canadian store...a little sarcasm there by the way. The bearing set is actually timkin, so no worries...just don't buy the mirrors
          • randy
            • Dec 2003
            • 4521
            Lacking a press, you can cut into the bearing with a dremel and use a chisel to snap it. Falls right off then!
            • prometheus578
              XS-XJ Super Guru (RESIGNED)
              • Aug 2004
              • 4012
              • Olympia , Wa.
              That's the way I do 'em, Randy. (Cutting wheel in a die grinder)
              Save the old races. Grind down the outer diameter on a grinding wheel(so they'll slid nicely in and out of the steering head) and use them to protect the new ones as you press(pound) them into place.
              Same for old wheel bearings.
              • DELL82
                • 260
                • Houston, Texas
                Just took apart the triple tree and found tapered roller bearings. Top was grease hardened and some rust, bottom was no grease but Okay. Cleaned both and found some brenelling(?) on upper but I think Okay What pre load do I put on the bearings when reinstalling? Using the notched nuts is there a way to use them to determine the proper torque, snug-up back off one notch etc?
                Dell82
                Houston, TX
                82' XJ1100J Maxim "LASERMAX"
                SOLD 86' Kawasaki Voyager XII, 1200cc SOLD
                SOLD 82' CB450SC Nighthawk, FOR SALE SOLD
                SOLD 82' CB450SC Nighthawk, parts bike SOLD
                  Here's the thread you want to check out for the correct torque for the steering head bearing.
                  There - post number 2000 and I didn't even have to fluff my way in. All I had to do was post a link to something I already posted once!
                  • webbcraft2150
                    • Sep 2002
                    • 1605
                    • AUSTIN.TX
                    While not the "official" procedure, I just tighten them up till there is no play or binding, kinda like a wheel bearing on a cage.
                      Hey TC
                      He cheated, he cheated, no fair! There's no double posting allowed! Delete Ken's post, and adjust his post count accordingly.
                      • prometheus578
                        • Aug 2004
                        • 4012
                        • Olympia , Wa.
                        DOUBLE GURU... DOUBLE GURU!
                        • DELL82
                          • 260
                          • Houston, Texas
                          snip) FWIW, my Yamaha shop manual says to install the bottom ring nut to 7.2 - 8.7 ft-lbs, and "do not over tighten it". A bit further on, they continue"When assembly is complete, check the steering stem by turning it from lock to lock. If there is any binding or looseness, readjust the steering stem tightness". (snip
                          I assume that bearings, nuts etc are greased up otherwise the torque will not be right I can use a 6" hook spanner and fish scale pulled to 15 Lbs should give me about 7.5 ft Lbs of torque, right!
                          Dell82
                          Houston, TX
                          • prometheus578
                            • Aug 2004
                            • 4012
                            • Olympia , Wa.
                            "You've got a lot of balls, Buddy"!
                            Tapered bearing set can be ordered from bike shops. Company called "All Balls". part number 22-1004. Comes with new rubber sealing washers for top and bottom. Retails fer $35.95
                            (Nobody has mentioned prices, so I did)
                            • DELL82
                              • 260
                              • Houston, Texas
                              Say Doc what is the site for "all Balls". I googled it and found bearings for Kawi's but no web site, any help is appreciated.
                              Just found it www.allballsracing.com
                              Dell82
                              Houston, TX
