How do you hide your wires?
  • Incubus
    • 1003
    • Austin TX
    I mean with a Vetter fairing. If I pull the headlight bowl - which will be redundant when I put on the fairing and also is too grungy for my soon to be fairly attractive widowmaker - where have y'all stashed the connections from the inside of the headlight?
    I hate to have them just tethered up there.
    Thanks,
    Patrick
    XS11F (Incubus, daily rider)
    1969 Yamaha DT1B
  • Jerry
    XS & TRUE XJ GURU
    • 3023
    • Elma, IA.
    Believe it or not, many installation just leave the wires, taped together into a bundle, just hanging out the front end of the bike.
    I have a Windjammer IV on my XJ; headlight shell is in place and wires are inside of it. Vetter also made a 'cap' that fits inside the headlight shell to close it off to the outside world. No clearance problems between the shell and the Vetter, plus it looks neat and would be easy to switch back to a nekkid bike. Depending on the model Vetter you have, try leaving the headlight shell in place and see if you get lucky.
    FWIW, I am using a Vetter mount originally installed on a Special. Don't think it is any different than the other XS 11 mounts, but have been told there may be minor differences due to the difference in rake between the standard and special.
    I removed the XJ headlamp to use in the Vetter; other than that only change was to remove the turn lights and replace them with short bolts to hold the headlight shell to the mounting ears. Again, there are some differences in the turn light mounting / headlight shells between models, so what works on the XJ may not work on your bike.
    Jerry Fields
    '82 XJ 'Sojourn'
    '06 Concours
    My Galleries Page.
    My Blog Page.
    • Poprock
      • Apr 2005
      • 594
      • Oregon Coast
      The King of Kong has a Pacifico, no headlight ears remaining. His wires are covered in a neat little leather bag that hangs off the back of the speedo-tach by the bolts and snaps together over the wires. I have no idea where it came from. Maybe a Pacifico thing?
      • planedick
        • Mar 2005
        • 2068
        • Yorba Linda, California
        Think so...
        Probably is a Pacifico thing as mine has the same leather bag. Trick is to tie 'em up inside the bag and after attaching to speedo bracket, just fold the ears over it. Now it's outa the way and outa sight.
        Drilled airbox
        Tkat fork brace
        Hardly mufflers
        late model carbs
        Newer style fuses
        Oil pressure guage
        Custom security system
        Stainless braid brake lines
        • Incubus
          • 1003
          • Austin TX
          Does anyone know where I could come by such a bag?
          Patrick
          1969 Yamaha DT1B
            I bought my last one from a local chainsaw shop. I believe it was disigned to be some sort of faller's tool pouch or first aid kit carrier. Mine is a heavy, cloth-backed vinyl with a snap closure 'flap' for the open end. I tucked the wires into a nice tight bundle, slipped the pouch down over it, then pulled the flap up between the wires and snapped it shut. The whole works tucks neatly between the folded-in headlight ears which are zip-tied together.
            • HobbyMan
              MeatHead Idiot "GURU"
              • 1801
              • Colleyville, TX
              are you talking about the bag that came original with the fairng? Most people say don't use it because it collects water and destroys the connections inside. My dad uses it, but our bikes are kept in the garage, nice and dry.
              Acta Non Verba
                I've got the original bag on Tsunami, while SWMBO's Purple Reign has the bag from the chainsaw shop. I've never had a problem with water getting into the bags. That may because the open end is down on both bags, or it may be because both bikes are also kept under cover year-round.
                • xszgrider
                  • Sep 2006
                  • 46
                  • El Paso, TX
                  I purchased my 1980 XS1100G with a Don Vesco fairing. There is a black plastic box bolted to the headlight mounting ears. All the cables run into the back of the box and one cable runs out the bottom that plugs into the fairing.
                  The box is approximatel 7.5" x 4.5" x 2.25". The top of the box faces forward and there appears to be a cover plate in front. I am unable to see the front of the box. It makes a neat installation if you have the clearance.
                  Hope this helps.
                  John in El Paso
                  1980 Yamaha XS1100G
                  2002 Honda Goldwing
                  1977 Yamaha TY250
                  1973 Yamaha TX750 (future project)
