Who can say with any degree of certainty if a cylinder head from an '80 motor will swap directly to a '79SF motor? For starters: I'm told the '80 valves themselves will not swap to the '79 head. Can anyone verify that offhand, or if not, does anyone know where to find valve specs for each year?
swapping cyl heads
swapping cyl heads
80G Mini-bagger
Past XS11s
79SF Squared-off Special, Vetter/Bates tour pkg., Mikes XS coils, G rear fender and tail light. Sold June 09Tags: None -
The heads will swap. But the valves 78-79 will not swap to 80-81. Or visa-versa.79 F full cruiser, stainless brake lines, spade fuses, Accel coils, modded air box w/larger velocity stacks, 750 FD.
79 SF parts bike. -
Thx .... I love this forum :-)80G Mini-bagger
Past XS11s
79SF Squared-off Special, Vetter/Bates tour pkg., Mikes XS coils, G rear fender and tail light. Sold June 09Comment
Wiz
Whatever you do KEEP THE 79 CAMS!
On thing you can do for performance is use the late (80-81) head with the larger valves but swap the late cams for the "hotter" early cams. And yes they should fit fine in the late head.Comment
hey maxx
yes, I was going to PM you the same question, and does it matter if the shims have to go back into the donating head since the lift/duration of the early cam is different. You see this is what I get for staying up late and reading my xs1100 manual!!!....chopMDRNF
79F.....Not Stock
80G......Not Stock Either....In the worksComment
Match w/cams used
Just to make sure you are understanding.. I don't know for sure if the 80 model head had the same valve clearances that my 82 did, but the book said to shim to .11-.15mm intake and .21-.25mm on the exhaust. I think I saw somewhere that it was .21-.24mm for the exhaust on an 80 model.. but don't quote me. The earlier model cams (78-79) had an adjustment of .16-.20mm for the intake side. This is the number you should shoot for. The exhaust was basically the same.
The closer you can get to the higher number, the better (IMO) As your valves wear (Or valve seats) over time, the gaps will actually get tighter between your shim and your cam. They will set deeper into the head. If you begin with it tight already.. just less time until you'll need to do this again.
TodLast edited by trbig; 10-13-2006, 04:29 PM.Try your hardest to be the kind of person your dog thinks you are.
