XJ11 Brake Discs are expensive!
  • rickmcdougald
    • Jan 2005
    • 97
    • Corvallis, Oregon
    Any ideas for good looking, but cheaper replacements?
    "Front Brake Caliper" (fiche)
    1 ea. 3H5-25831-10-00 Left DISC, BRAKE $294.20
    2 ea. 3H5-25831-00-00 Right DISC, BRAKE $244.80
    (pad set: 4w1-w0045-00)
    "Rear Brake Caliper" (fiche)
    1 ea. 10M-25831-50-00 DISC, BRAKE Price not found.
    (pad set: 4w1-w0046-09)
    Whaddya' think, guys?
    XJ1100J Maxim (Arlington)
    Ruby Red
    XS1100E (no name yet)
    Macho Maroon
  • mro
    • 4276
    • Hayward, California
    I'd look for some good used ones.
    Just one is more than I've paid for whole bike
    80/81 specials have sloted rotors and will fit
    mro
    • Pat Kelly
      • 3046
      • Golden Valley, AZ
      MikesXS.com
      Don't tell them they're going on an 1100.
      Pat Kelly
      <p-lkelly@sbcglobal.net>
      1978 XS1100E (The Force)
      1980 XS1100LG (The Dark Side)
      1999 Suburban (The Ship)
      1994 Dodge Spirit (Son #1)
      1968 F100 (Valentine)
        You say you want brake discs.... but are showing the prices to the CALIPERS. Which one are you looking for? Or am I reading that wrong?? PM Andreas.
        • rickmcdougald
          • Jan 2005
          • 97
          • Corvallis, Oregon
          The names of the exploded diagrams (aka "fiche") are from Yamaha.
          The part numbers are correct, but I had the Front, Right DISC quantity incorrect:
          1 ea. 3H5-25831-00-00 Right DISC, BRAKE
          The "10M" number on the "Rear Brake Caliper" (fiche):
          10M-25831-50-00
          tells me that it might only be made for the '82 US version of the bike. Is that right? ... anyone?
          I did check out MikeXS.com - the fronts are cheaper. They look different than the originals on my bike, but what the hey, if they fit?!
          I have to wonder about their dimensions - thickness, diameter, offset from their attachment points and the like.
          -R
          Ruby Red
          Macho Maroon
          • mro
            • 4276
            Fronts should not be a problem to find.
            Rear does have different pre-fix and could be different enough that only a 10M disk will work properly.
            MAXIMAN or John in texas may know for sure
            mro
              The Maxim calipers are different in appearance than the XS's, but I think they are the same dimensions internally, i.e. the caliper piston size is the same as the pistons on a Standard, (all three calipers), and the rear on a Special. If you need some calipers, I have a few that need kits, but the I think the pistons are still available. I'll go check on that in a few minutes. I have some in the garage.
              Duh! After re-reading the post, I realized that he was looking for rotors, not calipers.Sorry.
              Anything to increase the post count.
              • rickmcdougald
                • Jan 2005
                • 97
                • Corvallis, Oregon
                Hey, has anyone needed to replace their rotors?
                John,
                Thank you for the info on the calipers, too!
                Hey, has anyone needed to replace their XJ rotors?
                What did YOU do about obtaining (new?) rotors?
                Thanks,
                -R
                Ruby Red
                Macho Maroon
                • Fredjohny
                  • 74
                  • Gibsons, BC Canada
                  Eh,
                  I have a 80 xs1100 and a 82 xj1100, the only brake parts that interchange seem to be the rotors.....the mounting set-up is different, on the front forks, same with the rear.....the master cylinders are different too, due to the way the xj does front and rear at the same time through a proportioning valve.....
                  82 XJ1100 Maxim
                  80 XS1100 engine and parts doner
                  Awsome machine.....love going on rides.....
                  black on black
