i tried to remove the air pilot jet like the manual said, and of course I stripped the crap out of the slotted front. the hole is still fine, but I don't know if I should try to drill it out and re tap or pound a slotted screwdriver into it to remove it, or if I could get away with just leaving it alone.
help air pilot jet question
That pilot air jet is like a size #180. That's rather large.
If I could squirt some carb cleaner into that jet, and the juice comes out the pilot jet in the bowl area and out the pilot needle area, etc, I wouldn't worry my pretty little head over it. (I don't know just what kind of head you have, but you shouldn't worry about it, either.)"Damn it Jim, I'm a doctor, not a mechanic!' ('Bones' McCoy)
well, when the book says it should come out, I try to take it out. I don't know enough about carburators yet to know what absolutely has to come off and what doesn't. But carb #1 came out pretty clean, and I've got 3 more to practice on.
I just have to get new screws for the bottom rail. the original phillips didn't hold up very well. anyway, thanks
the original phillips didn't hold up very wellDo'Lee
XS1100SF "Green Hornet"
(1) XS1100LG "Midnight Dream" Restoration has begun.
(2) XS1100LG "Midnight Madness" Waiting to be next
(5) multi partsters for bobber "Ruby Red II" On the list.
SR500H "Silver Streak"
Is there somewhere to get a set ofreplacement screws for these? I'm about to do the rbuild on my carbs and I'd much rather have the screws here before I start.1979 XS1100 SF
Under Construction,
Due out by Spring '07
"Some days, it ain't even worth chewing through the restraints."
TomKat
Just take the original screws to any good hardware store. They are a fairly common size. I recommend allen heads screws, as a hex head may be too big for a socket to clear the bowl when removing the bolts. Allen heads work fine for me. Possibly pick up a 1/4" drive 4mm hex driver while you are there. That will make screw removal a snap.
