"Keyster" carb kits?
  • OneHand
    • 71
    • Jhb, South Africa
    Anyone tried Keyster carb kits? Seems to be all I can find locally, except for K+L which is not recommended.
    79F - "Anakin Skywalker"
    transforming into:
    "Darth Vader"
    You can use the K&L, just DO NOT use any of the jets. All you should need is a new needle and seat, and possably the float bowl gasket. Everything else on the carbs should be good. If you do have something worn, try to replace it with Mikuni parts, and not aftermarket.
    Ray
