carb cleaning
  • SiP
    • 438
    • Medicine Hat, Canada
    carb cleaning
    Do I really need a carb kit? Can I strip clean and re-assemble and just replace anything I find busted and leave it at that?
    Si Parker
    '81 XS1100H
    Tkat brace, new coils/wires/plugs, refurbed carbs (thanks 81 xsproject), recon'd top end, windshield (thanks dpotter58), resprayed tank and panels, 4-1 exhaust, sweet xs pod filters, in line fuel filters, progressive springs, thick hand grips, jumped headlight relay.
  • audijunky
    • Apr 2006
    • 707
    • VA
    You sure can, I prefer that method. First thing I bought was a kit and now I have extra parts. When you do the repairs you probably might as well go ahead and get 4 float bowl gaskets, thay tend to tear when opening bowl. depending on how long its been since it was opened last. From what I hear stay away from K&L parts. MikesXS.com has alot of good parts for our carbs.
    79 XS1100 modified standard
    straight pipe 4-2 exhaust
    Owned 83 Honda V65 Magna
    Owned 02 Vstar 650 classic
    owned 85 Honda Shadow VT 700C
    • HobbyMan
      MeatHead Idiot "GURU"
      • 1801
      • Colleyville, TX
      I have never found a nead for an actual kit yet. none of my 4 sets of carbs have needed float bowl gaskets. For me, they just stick to one side. I suggest just taking the jets and everything else out, cleaning them, and reinstalling. After I clean them, I run marvel mystery oil or some other cleaning substance through the gas for a tank or two. As long as you are careful and don't break anything, most likely, you won't need a kit.
      Acta Non Verba
        SiP,
        On mine, I replaced the needle/seat on all 4 carbs. everything else was cleaned. That was about 30K miles ago.
        Ray
