Specs/80LG
  • 80mdnt11
    • Mar 2006
    • 221
    • S.E. IL./ Olney
    Specs/80LG
    I remember seeing thread on this while back, will post here if anyone can use 'em as per my Yamaha Motor Corp. Spec book. Wish I had scanner/printer still, servicing higher education at diff. location for now so will try to be accurate!!!!
    XS1100LG
    Initial Eng. #/Frame #----------4H3-000001
    Basic Color------------------------New Yamaha Black
    Fuel type/tank capacity/res. cap.--Reg.(does not give oct. rate)
    15 lt. (4.0 gal) / 2.5 lt. (0.6 gal.)
    Dry vehicle weight---------------252 kg/556 lbs.
    Engine Type----------------------4-stroke, air cooled, DOHC, Transverse Four
    Bore/Stroke/# Cyl./Displacement (cc)------71.5mm / 68.6mm /4/ 1101cc
    Compresion Ratio/Compresion Pressure Min~Max.------9.0:1 /9.0~11.0 kg/cm2
    Piston Skirt Clearence New/ Max--------0.050 ~ 0.055mm / 0.1mm
    Ring end gap top / 2nd / 3rd-------------0.2~0.4mm/0.2~0.4mm/0.2~0.9mm
    Valve clearance (cold) Int/Exh-----------0.11~0.15mm / 0.21~0.25mm
    Oil press. hot / RPM------------------1.5 kg/cm2 @ 60*C / 1100 RPM @ Oil press. switch
    Oiling System--------------------------Wet sump
    Capacity: Dry-4000cc/Oil & Filter Chng.-3500cc/Oil Chng.-3000cc
    Lubricant: (as per specs!) Temp. Above 5*c/40*f--Yamalube 4 or SAE 20W40 SE,Below 15*c/60*f--SAE 10W30 SE
    Carb.- Mfr./ Type/ I.D. #-------------Mikuni/ BS34-lll/ 3J6-00
    Main Jet/ Pilot Jet---------------------110/ 42.5
    Needle Jet/ Jet Needle Clip Pos.---X-2/ 5GL16 Fixed
    Slide Cutaway or Throttle valve---135
    Float Level-----------------------------23.0 +/- 1.0mm
    Suspension-
    Front Forks: Oil Type/ Qty.---------10 Wt. Fork Oil/ 210cc
    Gas (Air) Press.-----------------------0.4kg/cm2 (5.7 psi)
    Spring length Std.--------------------612.2mm
    Min. Brake Lining Thickness--------Front: 6mm Rear: 6mm
    Tire Size (Normal Press.)-----------F: 3.50H19/ 26psi R: 130/90H16/ 28psi
    Transmission-
    Pri. Drive Type/ Teeth/ Ratio------Silent Chain x Spur gear/ 25-25 x 58-35/ 1.657
    Sec. Drive Type/ Teeth/ Ratio-----Shaft Drive/ 44-47 x 19-18 x 33-10 / 3.261
    Clutch Fric. Plate Thic. Std.~ Min.-3.0~2.8mm
    Clutch Spring Length Std.~Min.---42.8~41.8
    Midd. Gear Cap.----------------------375cc
    Final Gear Cap.-----------------------300cc
    Lube------------------------------------All Weather Cond.---SAE 80W90 Hypoid gear oil
    Charging System--------------------AC Gen./ 3 Phase/ Full Wave
    Max. Output--------------------------14v 20A @ 5000 rpm
    Feild Coil Color Code/ Ohm Rating-Rotor: Grn.~Blk./ 3.5 ohm +/- 10%----Stator: Wht.~Wht./ 0.4 ohm +/- 10%
    Ign. System--------------------------Transistor Controlled Ignition (TCI)
    Ign. Timming-------------------------5* Mark/ Std: 5* @ 1100 rpm/ Adv: 36.5* @ 3900 rpm
    Spark Plug Type--------------------NGK BP6ES or Champion N-8Y
    Spark Plug Gap/ Cap ohm--------0.7~0.8mm/ 5k ohm +/- 10%
    Ign. Coil Test Gap/ Pri. ohm/ Sec. ohm--6mm/ 1.5 ohm +/- 10%
    / 15k ohm +/- 20%
    Pick-Up Coil Color Code/ ohm---Org.~Blu, Gry~Blk/ 720 ohm +/- 20%
    Lighting System:
    Hedlight/ Taillight/ Signal Rating----12v60-55w/ 12v27-8w/ 12v27w
    Feel free to correct as needed. Seen Specs missing on left for this model. After all the help/advise/tech tips I received on my project from here, thought I would try to give a little back. If anyone can use these. I'm somewhat of the 'ol pack rat- this book is from '74 -'80 Specs ( some '81) for Yamaha Models. Kept ahold of it from the Yamaha dealership wrenching days back in the '70s-'80s.
    "Elvira"
    '80 XS1100LG
  • 80mdnt11
    • Mar 2006
    • 221
    • S.E. IL./ Olney
    Torque Values
    Front Axle Nut: 14mm x 1.25: 10.7 m-kg
    Front Axle Holder Nut: 8mm x 1.25: 2.0 m-kg
    Rear Axle Nut: 18mm x 1.25: 15.0 m-kg
    Rear Axle Pinch Bolt:8mm x 1.25: 0.6 m-kg
    Clutch Nut: 18mm x 1.0: 7.0 m-kg
    Drain Plug: 14mm x 1.5: 4.3 m-kg
    Not sure what conv. is to inch/ft. lbs.
    "Elvira"
    '80 XS1100LG
    • dpotter58
      • Aug 2004
      • 1866
      • Southern Maryland
      online conversion thingy..
      1980 LG
      1981 LH
