I had to go get a new battery and now I am charging it. It is your regular old lead acid Interstate and I am charging it with the partsnmore Emgo battery charger. My question is how long do I charge it, or how do I tell when it is done?
battery charging question
'81 XS1100 SH
Sep. 12th 2015
RIPTags: None -
Hey Jessie,
That charger is only a 1/2 amp charger, so you should probably charge it for at least 24 hours! IIRC, my new battery said to charge it on a 2 amp for about 10 hours! You definitely want to FULLY charge it before putting it on the bike and putting any loads to it, that way it will have a good strong charge memory!
T.C.T. C. Gresham
How nature points out the folly of men! -
Is there any way to check it? Maybe a certain voltage? I just got a fancy shmancy Craftsman multimeter to check
'81 XS1100 SH
Sep. 12th 2015
RIPComment
This info should have come with your new battery.
(tool for measuring specific gravity looks like a small turkey baster with a scale on it and float inside)
Fully charged (not sure but should be about 1.2 on scale) and battery voltage will read 13 plus volts (new batt.....first charge)
mroComment
