reserve lighting removal
  • chevy45412001
    • Mar 2003
    • 1412
    • Jacksonville Florida
    have an XJ lost headlight. First fuse blue then when i replaced fuse headlitw won't come on. put pos and neg wire on lite it works , so question how do i bypass rsu on the xj? I read the rsu bypass in tech section, but my wires are not the same colors as the XS's. any clues? TIA
    1982 XJ 1100
  • Dennyz
    • 1151
    • Olympia, Washington
    bypassing the RLU
    I tracked down the wires coming from the high/low beam switch and the wire from the head light on relay (on when engine starts).
    I installed 2 30 amp automotive relays ($6 ea). One drives the high bean and the other the low beam. I use the wires from the high/low beam switch to activate the relays.
    I mounted the relays in the headlight bucket and power them with a good size wire.
    DZ
    Vyger, 'F'
    "The Special", 'SF'
    '08 FJR1300
