Alright, I just gotta throw in my $0.02. I'm of the opinion that as long as the ends are the same (as mro suggested), it won't matter how the springs are installed.
Pro- I disagree. Looking at it from a statics point of view, if ten pounds is applied to one end of a spring, the force will be transmitted through it to the other end. Lets say that at this other end is the scale that Ken referred to and it is pushing back with ten pounds. Now if you were to look at the spring/initial 10# force (or spring/scale) interface only, you would have 10# pushing on the spring end, therefore the spring end would have to be pushing back on that 10# force with 10# of its own. If it were any less (or more for that matter), that interface would continue to move. If we're applying statics, everything counteracts everything and nothing moves.
Now, I do agree with Pro that the coils which are wound looser will compress first. I also agree that the end of the spring to which the initial force is applied will begin to move first, since it does take time to transfer force through any material.
BUT, I say that the amount of time it takes to transfer the force through the spring is so infinitesimally small, that it won't matter. By the time the force reaches the other end of the spring, the spring will have compressed only an infinitesimally small amount. Thus, since that compression is so close to zero, is effectively zero, and what remains is where they compress first. That'll be where the spring is wound the loosest, whether that loosest place is at the top of the spring or the bottom.
This is coming from a statics point of view. I never took a full course in dynamics, which, in actuality, is what we're talking about, but when it comes down to it, the principles are very similar.
I have been wrong before, so I welcome any and all critiquing of my stance. Have at 'er.
If one has a spring compressed with ten pounds of force, it will exert a counterforce of five pounds in each opposing direction.
