I just bought my first XS1100 I have a few questions.
First what I have is an 81 Special I think because it has buckhorn bars and a step seat. I want to know if they made two different frames or are the standard and the specials the same? Because I would like to but on a flat seat and super bike bars.
Also the PO drilled holes into the end of the exahust to make it louder. Wouldn't that effect the performance by losing the back pressure. The bike pops and back fires at slow speed.
Also wonder if 56k is alot for this model or are they pretty sturdy
engines?
Thanks
engines?
Thanks
The frame #'s are different between standard and specials, but it may be more to do with the smaller cosmetic changes, side cover mounts, etc.. The special side covers are slanted a bit more towards the rear to allow for the dip in the side of the seat. You should be able to put a standard seat on, or just take yours and have it recover modifying the cushion to remove the "hump"!
Most bikes from that era were about wore out at 40-50,000... so relaxe... yours is just now getting broke in!
