papanovember
You sound like a pilot??? no?
In any case I wouldn't hesitate to install an 1196. I am utterly pleased with mine. If you have an extra block...as I do...then you can always revert to it if need be.
I also have 4 different exhaust for Zilla. The kerker I have will not even come close to working with a standard oil cooler adapter. That is not to say that some kerkers won't with some adapter. Just not mine.
Having said that...I would not even begin to contemplate running an 1196 big bore with out a cooler...at least not the way I ride. The increased compression is really cranking out the heat on this motor at highway speeds ... especially across the desert.
This has been my experience so far. YMMV.
Good luck
Good luck
