Cleaning and preping heads ?
  • Filter
  • Cleaning and preping heads ?
    I have a xs 11sg (1980) I had bad compression in the #3 cylinder so I took the heads off! Good news, bad head gasket!
    I was wandering if any one had suggestions on how to clean and prep the heads to put them back on?
    They are in pretty good shape, how should I clean the carbon from the cumbustion chamber and piston heads?
  • #2
    I have used a cup type wire wheel in an electric drill before. Works pretty good, and doesn't harm the head or piston. If you use a small enough wheel, you can also get down into the ports to clean them.
    • #3
      Brass wire wheel would work well for that sort of job. When I cleaned up my head I soaked the chambers with gas by turning the head upside down and filling the chambers with gas. After a few hours the carbon came off pretty easy with a stiff plastic scrubby. Doing this will also tell you if the valves are sealing because if they aren't the chambers will not hold the gas.
      Just a note when your doing this .. DON'T remove the carbon ring at the top of the cylinders or the engine will start burning on you.
      Rob
      KEEP THE RUBBER SIDE DOWN
      1978 XS1100E Modified
      1978 XS500E
      1979 XS1100F Restored
      1981 Suzuki GS1100
      1983 Suzuki GS750S Katana
      1983 Honda CB900 Custom
