front caliper removal question
  • mattkey12
    • 8
    • Orlando Florida
    Is there only one bolt that holds the front caliper in place? I removed the nut but I could not remove the caliper. Thanks
    • 7735
    What model BIKE????
    The Standard has two bolts holding each caliper, the special has one.
    Ray
    • mattkey12
      • 8
      • Orlando Florida
      XS1100 SF. If I remove the one bolt it should slide off rite?
      • Pat Kelly
        • 3046
        • Golden Valley, AZ
        On a special there is one bolt holding the caliper to the fork. The bolt comes up from undreneath and threads into the fork. The nut you removed is a jamnut to keep the bolt from loosening.
        Pat Kelly
        <p-lkelly@sbcglobal.net>
        1978 XS1100E (The Force)
        1980 XS1100LG (The Dark Side)
        1999 Suburban (The Ship)
        1994 Dodge Spirit (Son #1)
        1968 F100 (Valentine)
