Last week I read several posts about replacing the cam chain.
The thread that I read started with a description of cutting the chain with a special tool, threading-in the new one, and splicing it back together with the same tool.
It was followed by several posts by others that had added clarification/comments of more thorough methods.
I have searched and searched, and can not find that posting.
I thought that it was in the "offline tech tips" but I am not finding it anywhere.
Anyone know what I am referring to?
TIA
TIA
This way, you can fish the cam down around the crank, and then once you get the new out around it, you can easily check that it's on the crank sprocket by rotating the crank a bit, and feel the chain move up or down depending on which way you are turning it and which end of the chain you are looking at. Then secure the ends, ensure you have the crank at TDC, then put the cams back in,dots up, sprockets, chain, and viola....no worries!!
