What to check before installing a used engine
  • acof911
    • Jun 2005
    • 244
    • S.E PA
    Hello All,
    I recently aquired a MNS engine with approx 20k on it. I want to check it out before I consider swapping it for the motor I am currently running.
    Here are the items I have on my check list, am I missing anything?
    Compression test
    Cam chain adjustment/ check
    Valve clearances
    Transmission check - suggestions on the best way to check this would be helpful!
    Clutch function
    thanks,
    Andy
    More than just a compression test, you might want to condsider a leak down test. The search tab at the top of the page should bring you some information.
    • acof911
      • Jun 2005
      • 244
      • S.E PA
      leak down test
      Thanks Ken, I will look into that.
      Andy
