Hi all, this is my first post as I recently acquired an '81 XS1100SH and I have a question concerning the master cylinder. I have switched the pull back bars for a standard type of bar and the master cylinder is now tilted and therefore wonder if air could possibly work its way into the lines?
Front master cylinder
air
i would think as long as the holes in the bottom of the m/c are covered with fluid you should be good to go?the only time air would get inside is if you remove lines or for some reason lose fluid.1982 XJ 1100
