criminny!
  • mixelpix
    • Sep 2004
    • 237
    • Utah
    criminny!
    coming home tonight i noticed a sharp pop and an increase in grumbliness from the exhaust on the right side of the bike. The noise seemed to be coming from the carbs, but it put my hand down and didn't feel any bursts of air or heat... Got home, looked at the engine and saw a faint blue glow coming from the fron of the bike...
    Your Mileage May Vary
    Studs broken off, or just worked themselves loose?
    • Just In Case
      • Apr 2006
      • 79
      • Auckland, New Zealand
      Seeing that has given me an idea... See through headers Now who has that receipe for transparent aluminium
      David
      XS1100G (3X1 000274) "Torquey"
      You can think of a lightning bolt as essentially a really really big bug zapper. Unfortunatey, we're the bugs.
      • mixelpix
        • Sep 2004
        • 237
        • Utah
        see through alright!
        Fortunately it's just the bolts having worked themselves loose and I have a spare set I can glom off another model, but it sure gave me a startle to see the blue light coming out of my heads!
        Must be something in the air tonight - an hour later there was a pretty major hit and run on a parked car on our block - the parked car got moved over ten feet up onto the lawn from the street! I'm just glad I made it through another day in one piece...
        Best,
        pdk
          • 5057
          If you are lucky, you won't need to replace the head pipe gasket(s).
          • jeffe
            • Oct 2004
            • 393
            • Westerville,Ohio
            I think Scotty gave the guy the formula in " The Voyage Home". I guess he hasn't marketed it yet.
            Think of the uses..........
            1.See thru gas tanks ....no gauge needed
            2.neon fired wheels....use them to hypnotize cagers into paying attention to bike riders
            3. see thru cylinders...wouldn't need a timing light...just see when number 1 is firing.
            78E ... Gone but not forgotten
            2006 Kawasaki Concours....just getting to know it
            • 81xsproject
              • 3185
              • Fortuna, CA
              Setting fuel mixtures would also be a breeze. No more glass spark plug needed.
              '81 XS1100 SH
              Sep. 12th 2015
              RIP
              • jeffe
                • Oct 2004
                • 393
                • Westerville,Ohio
                1No sight glass or dip stick needed to check oil...although I know a few dip sticks that this won't effect
                2.Unbreakable headlight lens
                3.Able to check oil and air filters with just a peek
                • JWSanders
                  • 879
                  • White House, TN
                  <holds mouse like microphone>
                  Computer...computer?
                  What's this, a keyboard? How quaint!
                  That's one of my favorite scenes from the star trek movies, When he makes the formula for transparent aluminum.
                  I've actually seen transparent aluminum, but it's composited with a ceramic, and mostly opaque. Not very useful as it is....
                  80 XS1100SG
                  81 XS400SH
                  Some men miss opportunity because it is dressed in overalls and looks like work. - Thomas Edison
                  A Few Animations I've Made
                  • Jeff
                    • Apr 2003
                    • 263
                    • Pocatello, Idaho
                    There's transparent concrete.... well...... almost transparent...... opaque maybe.
                    Light Transmitting Concrete
                    Whats being billed as transparent aluminum is actually a ceramic made with Alumina (aluminum oxide).
                    1978 XS1100E "Flashback"
                    "If at first you don't succeed.... Get a bigger hammer."
