GOOD DAY ALL, CHECKED MY OIL LEVEL LAST NIGHT BECAUSE I CHANGED OIL A FEW DAYS AGO, SMELLED GAS . WHEN I BOUGHT BIKE IT RAN, TURNED OFF ONE DAY TO GET A SODA AND IT WOULDN'T START. NO SPARK, FIXED THAT PROBLEM, NOTICE # CYL HEADER PIPE NOT AS HOT AS REST, TRIPLE CARB CLEANING WAS DONE AT THIS TIME ,EVERYTHING WAS FINE, BIKE RUNNING GREAT. BIKE STILL RUNS GREAT EXCEPT FOR GAS IN CRANKCASE. BIKE HAD GAS LINES GOING STRAIGHT TO CARBS, AND THAT'S THE WAY IT IS NOW. I TURN GAS OFF WHEN NOT RUNNING, FLOATS WERE SET TO 23MM, BUT GOING TO RECHECK SATURDAY, AND THE SHUT OFF VALVES WEREN'T LEAKING WHEN I REDID CARBS. COULD THERE BE ANYTHING I MISSED OR WHERE SHOUD I GO LOOKING FOR THIS PROBLEM
. THOUGHT I COVERED ALL THE BASES BUT I GUESS I DIDN'T. THANKS FOR ANY HELP GUYS TO MAKE THE PAIN EASIER.
75ft driveway and he had to pull right up to the bike!!!! what do you do....??? alot of thoughts ran thru my head. at work right now will post pics later so you all can laugh. i had to or i would have killed him!!! looking for a alt case cover now it's not the stock case cover, changed with the parts bike motor, my alt was melted so i switched... i think it 's from an xj i don't know.. got to work will post later when things slow down
