Question on Cam Chains
  • missinglink
    • Oct 2004
    • 59
    • Middletown, Delaware
    My cam chain adjuster is at it's limit so I'm probably due for a new chain.
    Question: How long can I go before I absolutely have to change the chain. (I know, I know, forever if I never start the bike '') but really, I am planning a ride this weekend, about a 1,000 miles or so, and I want to keep riding until it gets too cold to ride this winter and then change the chain. How big a risk is it to wait to make this a winter project?
    Thanks for the XSpert advise!
    Missing Link
    Keep the Shinny Side UP!!
    Re: Question on Cam Chains
    If the thing does not need adjustment now, it is not a worry until it does need it. If it is relatively quiet, go on that ride (or two or three).
    • missinglink
      • Oct 2004
      • 59
      Thanks for the feedback, Skids, I'm leaving for the Finger Lakes tomorrow.
      Missing Link
      • mro
        • 4276
        • Hayward, California
        missinglink???
        if you really are "missing a link" don't see how your chain can be loose
        mro
        btw
        you are aware of what happens
        should chain jump a tooth???
        • missinglink
          • Oct 2004
          • 59
          Nice one, Mike. I'm not missing a link - yet-.
          Missing a few marbles maybe.
          Missing Link
          • missinglink
            • Oct 2004
            • 59
            OK, did my weekend trip up to the Finger Lakes area of NY. Put 1,138 miles on the bike. She ran great except when I hit a big puddle on Saturday during a monsoon downpour. I think one of the coils got soaked and she dropped two cylinders.....all was well once we both got dried out that night.
            Has anyone else had a problem with the coils shorting out in wet weather? Just curious.
            Missing Link
              It is normally the primary wires, not the coil that shorts. I've had the problem once or twice myself on daily ride. Check the pickup coil wires, if the PO did a poor job on the repair, you may have a problem with a short inside the case. The other thing to do is use plenty of "dielectric grease" on ALL electrical connections. It will keep the corrosion down, and keep water OUT of the connectors.
              Ray
              • missinglink
                • Oct 2004
                • 59
                Thanks for the replay DiverRay. Some good advice since I'm the culprit that made the pickup coil wire repair about 20 years ago, I really should look there first! Now that you mention it, it did act up the worse when I accellerated from a stop.... Anyway, I'll give everything the once over from the pickups to the coils to make sure.
                Missing Link
