Question For Wisco Piston Kit Users
  • 79XS11F
    • 3563
    • Ottawa, Ont. Canada
    I am about to check ring end gaps so I can move forward with the work on my hop up engine. Wisco instructions say end gap should be .004 per inch of bore.
    The instructions say that additional gap may be necessary depending on engine mods. There is however NO guidance. I will on this engine have:
    accel high performance coils
    Exhaust side of head ported and somewhat polished.
    4 into one performance exhaust.
    pod filters.
    Should I be thinking about a larger end gap for the rings? If so by how much?
    The bike will not be raced.
    Rob
    KEEP THE RUBBER SIDE DOWN
    1978 XS1100E Modified
    1978 XS500E
    1979 XS1100F Restored
    1981 Suzuki GS1100
    1983 Suzuki GS750S Katana
    1983 Honda CB900 Custom
  • 79XS11F
    • 3563
    OK .. I have 2 and 9/10 inches of bore on #4 cylinder. If I understand this correctly that means I need 2.9 X .004 of end gap for that cylinder?
    That = .0116 of end clearance.
    Does that make sense?
    Rob
    1978 XS500E
    1981 Suzuki GS1100
    • pggg
      • 1609
      • NZ
      Rob if the machinist rebores the sleeves properly there won't be any hassles with ring gaps, about the only thing to do is make sure the 4 ring gaps on each piston are apart - not in line. Some mechanics spread the gaps 120 deg apart on all 16 rings(includes the oil rings)
      • webbcraft2150
        • Sep 2002
        • 1605
        • AUSTIN.TX
        "This bike will not be raced"
        Yeah right!!!
          • 7793
          Rob,
          Your figure should be good. Round it up to .012, and keep them all the same. As the rings wear in, the gap will open a little bit, so when you run it "hot", they should not bind and break.
          As pggg said, spread the gap around the bore, then follow the break in restrictions so the rings and cams all "wear in" properly. Once done, you should be able to get over 100K miles on the engine with no problems.
          Ray
          • 79XS11F
            • 3563
            The machine shop that did the boring did not have the rings. Just the pistons and the block. Now I checked the top and second rings on #4 and if I go by the numbers the top rings gap was too small and the second rings gap was too big. There's nothing i can do about any gaps being too big but should I not correct the gaps that are too Small?
            I do know to set up the gaps 120 degrees apart.
            Rob
            1978 XS500E
            1981 Suzuki GS1100
            • 79XS11F
              • 3563
              Yeah right!!!
              Well not in the "real" sense but there is no doubt that the throttle will be twisted from time to time.
              Rob
              1978 XS500E
              1981 Suzuki GS1100
              • 79XS11F
                • 3563
                another question about this hop up. Should I start running higher octane gas in this engine when the rebuild is complete?
                Someone told me I will have to!!
                Rob
                1978 XS500E
                1981 Suzuki GS1100
                  With the increase in compression, premium gas is a must, unless you like the sound of detonation.
                    • 7793
                    Rob,
                    You do want to have the ring gap at least to the minimum. If the gap is too small, then file a little off the end of the ring to adjust it. The big gap, you'll just have to live with. It should not make much difference, the bike will still be FAST when your right wrist wants it to go.
                    Ray
                    • 79XS11F
                      • 3563
                      Thanks John. I wanted confirmation on that one. At current gas prices I am glad it's a small tank compared to a car. What about the ethanol fuel. It is supposed to be cleaner but i am not sure about the octane rating.
                      Rob
                      1978 XS500E
                      1981 Suzuki GS1100
                      • 79XS11F
                        • 3563
                        Rob,
                        Ray
                        So it's a fiddle fart sort of job then eh.. file a little tiny bit and measure and file a little tiny bit and measure ..........
                        Rob
                        1978 XS500E
                        1981 Suzuki GS1100
                        • pggg
                          • 1609
                          • NZ
                          Just being difficult here, but my bike's got wiseco pistons and all the other drama - and there's no noticible difference between regular or high octane. The high stuff burns slower so's less chance of knocking but My ignition timing is even 5 degrees advanced and regular is still fine. 11:1 isn't that high. Run BP7's or 8's tho.
                          • mro
                            • 4276
                            • Hayward, California
                            When you get em where you want em,
                            put a very slight bevel top/bottom of ends.
                            mro
                            • 79XS11F
                              • 3563
                              Re: file a little tiny bit and measure and file a little tiny bit and measure ..........
                              mro
                              Will do. I guess that's what they mean by taking a stone to the files ends eh?
                              As for compression i have been led to believe that the final compression ratio will be 10.1 to 1 which is up from stock 9.1 to 1.
                              Is that spec in the paper work that cames with the pistons?
                              Rob
                              1978 XS500E
                              1981 Suzuki GS1100
