Not answered please advise
  • 79XS11F
    • 3563
    • Ottawa, Ont. Canada
    Can someone tell me if these are the correct plastic floats to buy from Mikes XS
    http://www.mikesxs.com/mikesxs-fuel...category_id=4.2
    Part #20-6502
    about 1/2 way down the page.
    says
    Plastic Carb Float - Fits: 1980-84 XS650 Stock 34mm. Mikuni CV Carbs.
    This looks like it is the correct replacement float based on carb description but if anyone knows it would be nice to have some sort of confirmation before I order them at 12 bucks USD a peice.
    Thanks
    Rob
    KEEP THE RUBBER SIDE DOWN
    1978 XS1100E Modified
    1978 XS500E
    1979 XS1100F Restored
    1981 Suzuki GS1100
    1983 Suzuki GS750S Katana
    1983 Honda CB900 Custom
    I saw the plastic floats there at Mikes, and they had a 3H5 P/N. That is the prefix for an 80G so they sould work. I have a set of plasic floats in a set of 78 carbs, and they are working fine, so that tells me that they would be interchangable from the 650 to all models of 11's...I just checked YamaMama's parts site, and the P/N of the floats is definitly the correct one for the 80G. The 79 F uses a totally different P/N... it's a 2A2 P/N for the 79F.
    • 79XS11F
      • 3563
      This type is the only plastic floats I found on Mikes site. So in your opinion these would be the ones I need?
      Rob
      1978 XS500E
      1981 Suzuki GS1100
        Yeah. Buy 4 of them, and set the heights to the specs for an 80 SG. Are you putting them on a 79F?
        • 79XS11F
          • 3563
          Thanks
          Yes I am going to use them on my 79F to replace the stock brass floats that seem to be inconsistent. I want to eliminate the floats as an issue.
          Rob
          1978 XS500E
          1981 Suzuki GS1100
          • randy
            • Dec 2003
            • 4521
            I have the plastic floats in my 79F. Did yamaha switch from brass to plastic in mid-year 79? Kind of like the tubeless rims? or do you think the PO swapped floats? The carbs are definitely 78-79 type.
            • underdog57
              • 321
              • Alburgh , Vermont,054
              brass or plastic
              Randy , I'll bet yours were swapped ??
              Mine are brass also on a 79 sf. They look fine, wonder if they foat the same ?
              Bob
              1979 XS1100 SPECIAL (under 18,000 miles Sold 5/12/2016
              1982 XJ1100 MAXIM(PARTS BIKE??)shows 14,000 miles ??? Up for sale whole or parts
