82 XJ Carb rebuild kits ??
  • 82 XJ Carb rebuild kits ??
    Any source for these ?? I see bowl gasket and float needle seperate , so far ...
    I did a number on the float needle seats getting them out ...
    So could use them . should of used needle nose pliers , whoops .
    Bob
    1979 XS1100 SPECIAL (under 18,000 miles Sold 5/12/2016
    1982 XJ1100 MAXIM(PARTS BIKE??)shows 14,000 miles ??? Up for sale whole or parts
    All you should need is the float needles and seats (with o-ring). I just cleaned up the exisisting jets very well, replaced the needles and seats... I may have repaced the mixture screw o-rings and washers as well but you can find a match at a good auto store. I cut gaskets from sheet material bought at Fleet Farm for 4.99. Much cheaper than buying the gaskets individually. If you need a couple needles I think I still have (3)
    Tom B.
      XJ Carb
      Hey Tom ,
      My carb looks good also . the float valve seat would be good to replace ...plus the needle
      Like you say , everything looks really good ...
      I did take a look at the throttle shaft seals and will change them .
      They crumbled and tore apart very easily ...
      One set of butterfly screws is being a pain , but will get a better screwdriver . Already ground the backs of those screws ...
      Thanks for the reply
      Bob
