Brake upgrade basics
  • DeanR
    • Jan 2005
    • 1490
    • Finger Lakes NY
    Just installed stainless steel lines up front. This is my first time working on an empty brake system. Searched for a step by step tech tip or thread about filling and bleeding. Found a lot as usual, but not just those basics. If you guys would be so kind as to let me know what to do to fill and bleed I can go riding tomorrow!
    Thanks
    80 SG
    81 SH in parts
    99 ST1100
    91 ST1100
  • Pat Kelly
    • 3046
    • Golden Valley, AZ
    The very basic for bleeding brakes in an empty system is to
    - fill the master cylinder
    -open a bleeder valve
    -leave the bleeder valve open and let the brake fluid drain down the brake hose and fill the caliper until brake fluid comes out
    -close the bleeder
    -open the other bleeder
    -repeat as above until brake fluid comes out the bleeder
    -close the bleeder then pump the brake 4-5 times and hold it in/down
    -open the bleeder, ideally brake fluid will squirt out with maybe some sputtering.
    -close the bleeder
    -pump the brake 4-5 times and hold it in/down
    -open the bleeder
    -When you get good pressure built-up at the brake lever and no supttering from the bleeder then you are done....
    -repeat for other side.
    Pat Kelly
    <p-lkelly@sbcglobal.net>
    1978 XS1100E (The Force)
    1980 XS1100LG (The Dark Side)
    1999 Suburban (The Ship)
    1994 Dodge Spirit (Son #1)
    1968 F100 (Valentine)
    • DeanR
      • Jan 2005
      • 1490
      • Finger Lakes NY
      Thanks Pat!
      I've read about all the problems and ideas about bleeding, but this is exactly what I needed. A one man job?
      80 SG
      81 SH in parts
      99 ST1100
      91 ST1100
      • DeanR
        • Jan 2005
        • 1490
        • Finger Lakes NY
        Would this straight fitting have enough room at the bleeder
        or would this 35 degree fitting work better? I was trying to avoid the big bend in it (more of a bend than stock)
        Hope I posted the pics correctly
        80 SG
        81 SH in parts
        99 ST1100
        91 ST1100
          Dean,
          You used the link for the Photodump VIEWER, not the actual photos, so I fixed it!
          Either one should work, you just need enough room to be able to put a wrench on the bleeder, and also to fit a hose to the end of it so that you can see the bubbles, and when they stop, and run the hose into a catch can!
          • DeanR
            • Jan 2005
            • 1490
            • Finger Lakes NY
            Thanks TC
            Always manage to forget which is the right link to use.
            80 SG
            81 SH in parts
            99 ST1100
            91 ST1100
            • DeanR
              • Jan 2005
              • 1490
              • Finger Lakes NY
              Brakes feel great.......
              Bleeding was simple!
              80 SG
              81 SH in parts
              99 ST1100
              91 ST1100
