ignition switch
  • tjfisher30
    • 79
    • orlando fl
    ignition switch
    ok has anyone had the ignition switch go out on them one day i just about got everything ready running no i charge the battery and nothing i can jump it then she fires up once i take the screwdriver off the start slinoid she dies ?
    80 xs11 sg
  • andreashweiss
    • 951
    Good morning, in case you need a replacement. I have used ignition switch,gas cap,and sidecover lock all with same key for a special. andreas
      Hey TJ,
      The ignition "keyed" switch can get corroded, the wires can come off of their soldered connections, etc.!!! But start with the basics, check your fuses. You have an 80SG, I think it still has the Ballast resistor, it could be bad. During startup it's bypassed by the TCI, but once the engine is running, the power for the coils is routed thru it, but if it's broken, then it won't allow current thru it!?
      You can also take your ignition switch apart and inspect it for damage/corrosion, broken solder joints!
      • randy
        • Dec 2003
        • 4521
        TJ;
        What TC said. Ballast resistor is suspect. Try starting it and hold the starter button in, If it keeps running, it's the ballast.
        • tjfisher30
          • 79
          • orlando fl
          ya that seen to be whats happening so where can i get a new one ?
          80 xs11 sg
          • andreashweiss
            • 951
            I have a good used ballast resister. andreas
              • 7692
              TJ,
              Go with andreas for the parts. Good price, quick delivery and a good XSesive. The other thing is buy one from an auto parts store, and jury rig it to the bike. It can work and look good, but the time may be more than the cost of a "new" part.
              Ray
