Idle jet broken
  • Filter
  • Idle jet broken
    I read all the posts on this , and I keep bending pins , push pins etc ...This is realy kicking my butt ...
    Might try again with a hot air gun to the body , might expand a tad ???
    Any other suggestions??
    Bob
    1979 XS1100 SPECIAL (under 18,000 miles Sold 5/12/2016
    1982 XJ1100 MAXIM(PARTS BIKE??)shows 14,000 miles ??? Up for sale whole or parts
  • #2
    Drastic situations
    Put the two carbs in the freezer , then will use the heat gun .
    If I have two can get it drilled out at a machine shop ??
    Its tight allright !!
    Bob
    • #3
      On one of your carbs that you can get the "needle" out, find a finish nail that will JUST fit in hole. With said nail grind/file off point to make it flat. May have to shorten nail to fit in carb.
      Either have an extra hand hold carb or carefully place in vise (soft jaws/rag etc.) Hold nail w/needle nose plier in position. I put a small nut in carb (pivot point) and used a flat screw driver to push nail.
      Hope above makes sense
      mro
      • #4
        perfect scence
        MRO
        Will dig into so brad nails ...
        Its still in the freezer , will give it atry when I get a chance..
        Thanks
        Bob
