Well, I checked my valves ;
Intake shim size
specs .11-.15
1- .076 270
2- .127 260
3- .152 280
4- .064 270
Exhaust shim size
specs .21-.24
1- .152 285
2- .203 280
3- .203 275
4- .127 280
Since they were almost all tight I figured I would do them all. I pulled the cams and replaced with the appropriate shims, according to the Excel spreadsheet. When I put everything back together and went to check them, I got these readings
Intake shim size
specs .11-.15
1- .330 235
2- too thin 275
3- too thin 320
4- .406 220
Exhaust shim size
specs .21-.24
1- .508 225
2- .279 270
3- .254 265
4- .483 200
Intake #2,3 were too thin to measure.
I am going to put valve cover back on and run it a bit and recheck. What did I do wrong?! Did I miss something?
Intake shim size
specs .11-.15
1- .076 270
2- .127 260
3- .152 280
4- .064 270
Exhaust shim size
specs .21-.24
1- .152 285
2- .203 280
3- .203 275
4- .127 280
Intake shim size
specs .11-.15
1- .330 235
2- too thin 275
3- too thin 320
4- .406 220
Exhaust shim size
specs .21-.24
1- .508 225
2- .279 270
3- .254 265
4- .483 200
