1979 VALVE SHIM SIZE? 29? Anyone?
  • cafexs1100
    • Jun 2006
    • 13
    Hi, anyone know the valve shim size on my 79 xs1100. 29mm maybe? Thanks!
    Also, any one have any of these sitting around for cheap?
    karl -
    http://www.caferacermotorcycle.com
  • John
    • 5117
    Shim sizes
    There should be a number on the side of the shim that is away from the cam. The shims vary in size, from around a #250- #290 are some of the more common sizes that I have. Do a search here for shim thickness, and diameter. It has been discussed here numerous times.
    • Targetman
      • Feb 2003
      • 130
      • Oshawa Ontario Canada
      I found this site which lists a 29mm diameter shim kit and includes the xs1100 in its description..
      http://www.procycle.us/hotcams/valve_shims.htm
      1979 xs1100sf
      1972 cb500 four
      • mro
        • Oct 2005
        • 4276
        • Hayward, California
        cafexs1100
        Shim(s) missing????
        If you no got a manual, get one. Will detail how to adjust valves as well as many other necessary procedures.
        mro
