Another Carb Question
  • 80mdnt11
    • Mar 2006
    • 221
    • S.E. IL./ Olney
    Dissected carbs. Yep sure enough, pulling out idle screw washer/o-ring and DANG-IT !@#$%^&*!!!!!! Washer bounced off wire, to the leg and destenation under the bench! Well, spent an hour lookin for that dam# little thing before givin in for now. That was carb #1, went to #2. This Idle screw wouldn't even come out! Had to drill and easy-out------saved the carb body! WHEW!!!!! Rest went ok.
    Mikesxs has mixture screw part # 48-5011 for BS34. Does anyone know if these will work. '80LG
    Thanks
    "Elvira"
    '80 XS1100LG
  • rappin
    • 48
    • South Georgia
    How do you keep the main idle screw from backing out? I could try thread lock but I may want to adjust it later. Has anyone had this problem before?
    79 XS11
    • randy
      • Dec 2003
      • 4521
      rappin;
      Main idle screw should have a spring on it to keep it in tension so it doesn't move on it's own.
      • LoserShoes
        • Apr 2005
        • 524
        • Bangor Maine
        You need to get yourself a big magnet, assuming the washer is steel, and that washer will jump right off the floor onto the magnet. I have an old car speaker that I use for searching for bits like that.
        Steve
        73 Yamaha DT3 - DirtyHairy
        CZ 400 MX'er
        68 Ducati Scrambler
        RC Planes and Helis
        • 80mdnt11
          • Mar 2006
          • 221
          • S.E. IL./ Olney
          Yea, the BIG magnet is attractive possibility. Will try this morn. I should make correction however, this is the Idle Mixture Screw I am refering to.
          "Elvira"
          '80 XS1100LG
          • Brian_D
            • 355
            • Gardner, KS
            80mdnt11,
            # 48-5011 from MikesXS fit perfectly on my '81 LH so it should work fine on your '80 LG. Of course, if you still have the screw and spring then you could save a few bucks and purchace # 48-5012.
            Brian
            • rappin
              • 48
              • South Georgia
              Yes the main idle screw has a spring on it I also have a spare set of carbs and swaped idle screws and spring and still backs off. Someone said that I could get the idle set then put some paint or nonpermanent thread lock om it. The bike runs great until idle screw backs off.
              79 XS11
              • prometheus578
                XS-XJ Super Guru (RESIGNED)
                • Aug 2004
                • 4012
                • Olympia , Wa.
                "My "cross-dressing" secrets)
                Use a drop of your favorite fingernail polish. I like "Ruby Passion Red". (Stay away from the glittery stuff... too gaudy and usually clashes with my outfits)
                • randy
                  • Dec 2003
                  • 4521
                  Rappin;
                  That's probably because you're re-using old springs. Try stretching the spring a bit to provide more tension, or replace 'em
                  • rappin
                    • 48
                    • South Georgia
                    Thanks for the input all. I'll use one of the methods.
                    79 XS11
                    • prometheus578
                      • Aug 2004
                      • 4012
                      • Olympia , Wa.
                      "Ooohh, Ooohh... Pick me...Pick me!
