Anyone tried putting polyurethane motor mounts instead of oem rubber?
new type motor mounts
When I pull the motor to detail my LG I plan on using poly for the motor mounts.Pat Kelly
<p-lkelly@sbcglobal.net>
1978 XS1100E (The Force)
1980 XS1100LG (The Dark Side)
1999 Suburban (The Ship)
1994 Dodge Spirit (Son #1)
1968 F100 (Valentine)
"No one is totally useless. They can always be used as a bad example"Comment
I don't have them yet. When the time comes I'll head to the 4x4 shop I used to work at and compare them there.
Energy Suspension sells poly bushings. If the have an on-line catalog you could probably find them by dimension. They would be easy enough to 'modify if need be so a larger diameter or smaller bolt hole would be easy to dial in.Pat Kelly
poly
Hey pat, please keep me posted, that sounds like a better idea than mine. I was looking into getting some poly tube stock and cutting it to length. The only problem is that it looks like the bolt diameter on a couple of the mounts are different. I really can't tell on the rear mounts....any idea there?MDRNF
79F.....Not Stock
80G......Not Stock Either....In the worksComment
