Well boyz I'm utterly BUMMED!
I'll get all this info up and posted in a thread later to let you all know what the heck is going on with Zilla.
We've had pretty good results with hop up so far. But the Motad header ...I hate to say and hope it doesn't piss any of UK friends off...the Motad is a dawg.
With the Motad installed and the bike tuned the most we could get was 80 hp. With the OEM exhaust and bike tuned we're seeing 87-88 hp. I am certain when I can find a good Kerker or Supertrapp...or V&H header for the Eleven will see an Additional 10 - 12% on top of that 88. This would put us around 96 to 98 hp at the rear wheel.
Also I haven't explained the dyno we are using is very conservative for bikes. It was designed for legend racecars. Generally you can add 4-5 horsepower onto any of these numbers and that would be what you'd see on a Dynojet 250. As a matter of fact as soon as I get this baby dialed in best we can I'll take it to another dealer to run it on a Dynjet 200 series dyno just to get an A-B comparo.
As it is I'm stuck with the OEM exhaust and about 10% shy of where we should be. I've ridden the bike and there is a huge difference. Bone stock Zilla was dyno'd back a few weeks ago at 72 hp. Now it's at 87 hp which is a 21% increase in peak power with the OEM exhaust.
Here's a pic of the Motad. Pay close attention to the collector diameter versus the primary pipe diameters.
If you look at other 4 into one headers the primary pipes flow into a collector that is significantly larger than primaries. However the Motad maintains the same diameter pipe through out the flow path! This must creatre a restriction. You're trying to flow the gas from four (4) w35 mm down pipes into one (1) 35 mm collector! What type of idiocy is that?
Look at any other 4 into 1 and you'll see the collector is much larger than the down pipes.
Seriously...my OEM pipes flow quite a bit better than this piece of British Sterling (read BS).
I'm looking for a bedderhedder. I've come this far and spent this much so I'll have to sit tight until a slick Supertrapp or Kerker pops up.
If I have four 2 inch pipelines from four wells in the field and they are all feeding equal volumes of gas into ONE 2 inch pipeline I will have an INCREASE in pressure at the point of convergence. You would need a 4 or 6 inch line to feed these into. (the function of gas flow volume in any pipe is directly proportional to the area of the diameter of the pipe - pi*r*r)
