calling all gurus
  • xschop
    • Feb 2006
    • 1794
    • oklahoma city
    calling all gurus
    Serious question here...Since I don't have the original gauges on my 79F 'Blue Streak", can I hook up an oil pressure warning light to the oil pressure sending unit directly, or does that thing have to go to the brain box first then on to the gauges?.... Thanks to all in advance
    MDRNF
    79F.....Not Stock
  • Winterhawk
    • Jun 2004
    • 684
    • Missouri
    Just run a positive wire to one side of the light. A negative side to the sending unit. It will work fine.
    • xschop
      • Feb 2006
      • 1794
      • oklahoma city
      sending unit
      so the sending unit is not tied into the brain box?
      MDRNF
      79F.....Not Stock
      • xschop
        • Feb 2006
        • 1794
        • oklahoma city
        Ah-Ha
        so you mean a battery positive to the light, then from the light negative to the sending unit?
        MDRNF
        79F.....Not Stock
        • tab1324
          • 303
          • Brooklyn Park, MN
          If you want guages, I've got em
          check on ebay for the gauges I'm selling if you're interested. They're from a 78.
          Tom B.
          • xschop
            • Feb 2006
            • 1794
            • oklahoma city
            oh boy
            Thanks, I have 3 sets of guages, none look good on Blue Streak.
            MDRNF
            79F.....Not Stock
              Re: Ah-Ha
              The OP sender just makes ground for the dircuit. Just make sure you have it in a switched circuit, or the light will stay on when ever the engine isn't running, and the ignition switch is off.
              • xschop
                • Feb 2006
                • 1794
                • oklahoma city
                ground
                I thought that the OP sender makes ground when the oil pressure goes down to a certain level, triggering the light. If this is true the light should only come on at low pressure, no matter if it is wired straight to the battery?
                MDRNF
                79F.....Not Stock
                  I believe the light will come on at around 2-5 psi. It's nothing more than a pressure switch. When there is pressure, then the path to ground is broken, hence no light.
                  • xschop
                    • Feb 2006
                    • 1794
                    • oklahoma city
                    now that makes sense
                    I will hook it up this weekend
                    MDRNF
                    79F.....Not Stock
                    • randy
                      • Dec 2003
                      • 4521
                      You're absolutely right.
                      What John tried to tell you is, if you wire it directly to the battery, the light will be on even if the bike is off!
                      • xschop
                        • Feb 2006
                        • 1794
                        • oklahoma city
                        another ah-ha
                        Thank you both. I wasn't thinking about low/no pressure when bike is off. So which fuse should I run it off of?. Also what is the normal oil pressure when bike is running? I just want an idiot light on my tree...thanks again
                        MDRNF
                        79F.....Not Stock
                        • mro
                          • 4276
                          • Hayward, California
                          oil psi
                          cruising speed oil pressure 42 psi
                          oil warning light actiation 4.2 psi
                          relief valve opening 70 psi
                          cruising speed 55 mph
                          oil temp 216 F
                          ___________________
                          Good book doesn't say psi at idle
                          (well....... if it does, I didn't find it)
                          mro
