needle jets/emulsion tubes
  • tommystinson
    • Aug 2003
    • 425
    • Albany, NY
    OK, I figure that I've wasted enough time. '79SF, I.E. BS34 series II carbs. Has anyone, anywhere, found a source for the needle jets? Preferably real Mikuni, but I'm flexible and I'll buy what I can get! Thanks, Tommy P.S. Anyone with good slide diaphragms that can tell me how long it should take the slides to drop when plugging the vent hole?
    2010 Kawasaki Z1000
    1979 SF: Millennium Falcon, until this Saturday
  • mro
    • 4276
    • Hayward, California
    mikesXS
    http://mikesxs.com/mikesxs-fuel_syst...ategory_id=4.4
    scroll down, be sure it says it's for the bs34
    • tommystinson
      • Aug 2003
      • 425
      • Albany, NY
      Thanks MRO, I've been looking at those for a while. Same type, but different size ID and hole placement. I need a X-2 type to match with the 5GZ6 needle. Sigh.
      Come-on XSsives! Can anyone tell me how long their slides take to drop when plugging the air jet/vent? Tommy
      2010 Kawasaki Z1000
        I don't know...maybe 10 seconds?
        Originally posted by tommystinson
        [B
        Come-on XSsives! Can anyone tell me how long their slides take to drop when plugging the air jet/vent? Tommy [/B]
        • tommystinson
          • Aug 2003
          • 425
          • Albany, NY
          Thanks Skids, I'll check them out tonight. Any idea/is there a way to use a MityVac pump to check for correct opening vacuum?
          2010 Kawasaki Z1000
          • shotgun
            • Feb 2006
            • 10
            • Knoxville, TN.
            needle jets are still avaliable from yamaha, just a bit priceyat about $27.00 each
              You can watch operation with a shop vac just to ensure smooth operation... they should rise quick quickly about half way and then rise slowly to the top, when the throttle plate is wide open. At least, this is how they work with my Sears shop vac.
                Of course you can also check for smooth slide operation by manually raising the slide, and allow air to squeek by your thumb which is covering the oval hole.
                • mro
                  • 4276
                  That's a long time. Mine go down in about 3 seconds, from pushing up about 2/3rd way.
                  If there supposed to take that long, I may have issues, but she runs pretty darn good "as is" from idle thru red line.
                  mro
                  btw
                  did not notice "pluging vent hole" , did not do that so will check next time have em off.
                  • tommystinson
                    • Aug 2003
                    • 425
                    • Albany, NY
                    I'm picking up a can of plastidip rubber spray just to be sure. I was actually thinking about pulling the cone filters off and videotaping them. My camera will fit in the space OK, so why not?
                    2010 Kawasaki Z1000
                    • btchalice
                      • Jul 2005
                      • 55
                      • wichita, ks
                      the whole carb kit is cheap at z1
                      http://z1enterprises.com/detail.aspx?ID=500
                      79 xs1100 standard
                      76 kz900 <now 1015
                      Terry Meyer
                      • tommystinson
                        • Aug 2003
                        • 425
                        • Albany, NY
                        Unfortunately, the kit includes everything but the needle jet. I've got some used carbs coming, so I'm curious to see what condition the jets are in when they show up. Very small amounts of wear on either the needle or the jet I.D. can seriously affect the mid-range mix. I noticed one of my needles was slightly scuffed when I cleaned the carbs first time around, so jet wear is likely. The BS34II is something of a nightmare for parts. I can see FI or other carbs in the future.
                        2010 Kawasaki Z1000
                        • andreashweiss
                          • 951
                          I still have a small plastic bag of used xs1100 carb parts. The stuff that belongs inside. I may have what you need. Send me a picture of what you want might be able to help you out. working 8am-midnight today so cannot check e-mail until tomorrow. andreashweiss@yahoo.com
                          • Brian_D
                            • 355
                            • Gardner, KS
                            btchalice,
                            noticed the link you posted for z1 is for a K&L carb rebuild kit - beware - the K&L jets (pilot jet, main jet, etc) are probably the wrong size - at least they do not match up with the original/stock Mikuni jets.
