Stripped thread repair on fork brace?
  • gnevelesx08
    • Apr 2005
    • 107
    • Whidbey Island, Washington State
    I baught a torazzi fork brace on ebay. When I went to install it I found threads stripped on the right side clamp. My question is, is it possible to repair these threads with heli-coils? there doesn't look like a lot of metal surounding the threaded hole and I don't know what size I would need. I have asked the seller if he will refund the purchase if they can not be repaired. Aslo because of the stress on this area, would heli-coils hold? Please if anyone knows about this or have tried it, I would apreciate any info. Thanks
    Dan
    80XS1100G (Ebaybe) Whidbey Island, WA
    Lightning of 4 is better than thunder of 2.
    I always wanted a Harley. Not anymore! XS11 rules!
  • Pat Kelly
    • 3046
    • Golden Valley, AZ
    JB Weld, drill, and tap
    Pat Kelly
    <p-lkelly@sbcglobal.net>
    1978 XS1100E (The Force)
    1980 XS1100LG (The Dark Side)
    1999 Suburban (The Ship)
    1994 Dodge Spirit (Son #1)
    1968 F100 (Valentine)
    • gnevelesx08
      • Apr 2005
      • 107
      Thanks Pat, I will make that first consideration on list of possibles. I have used JB Weld before, drilled and tapped, but am concerned about the stress load since it is the clamp screw/bolt receiver threads. I will need a good machine shop, I don't have a drill press to make sure the drilled hole is true.
      • mro
        • 4276
        • Hayward, California
        If enough metal around hole
        would tap it out to next size bolt that would fit.
        Be it metric or sae
        mro
        • Geezer
          • May 2003
          • 2985
          • Willamina, Oregon 97229
          I would need to see a picture of the hole in question to give you an educated reply.
          If there's enough meat there to tap it to the next size up hole, then there is enough space for a healicoil.
          If it were mine, I'd do like you and pursue a return for refund.
          Geezer
          • andnew
            • Apr 2006
            • 50
            • Enumclaw, WA
            I live in Enumclaw and will be home all weekend while the family is away. I have a milling machine, drill press and metric taps, welders...
            we can fix it.
            All it will cost you is gas to get here.
            PM me if you'd like me to help.
            Cheers!
            Andy Newell,
            Enumclaw, WA
            03 BMW K1200RSA (Dread Zeppelin)
            1996 Triumph Tiger
            • gnevelesx08
              • Apr 2005
              • 107
              I bow to all.
              I got a great reply back from the seller. He said he didn't know it was stripped. He is willing to refund the purchase price, ($35.00). I want to try to fix if possible. This brace has a single allen head screw on each side of clamps. I'm not sure if I can post a picture but I think there is very little metal around both pieces to be able to re-tap to next size.
              Andrew- Have to check with SWMBO about a trip to Enumclaw this weekend, have to get the roof on the front porch before we get rain again. (I think the fork brace is more important!) I will PM you if I can make it. I haven't even taken the bike off the island yet!
              • Pat Kelly
                • 3046
                • Golden Valley, AZ
                Can you drill all the way through and use a longer bolt with a nut?
                Pat Kelly
                • xschop
                  • Feb 2006
                  • 1794
                  • oklahoma city
                  alumiweld
                  this is a solid fix. The company is now online.
                  MDRNF
                  79F.....Not Stock
                  • Douglas Money
                    • Jun 2006
                    • 179
                    • Braidwood IL
                    How many here have used fork braces? Do they really stiffen it up that much? I am thinking about putting on a set.
                    1979 XS1100F (runnin the wheels off it)
                    1979 XS650 (ran the wheels off it)
                    1976 CB550F (ran the wheels off it)
                      Hey Doug,
                      Well, TKAT once stated that he had sold about 1,000 of them over the years!! Here's just one of many threads singing the praises for his product!
                      TKAT FORK BRACE thread .
                      • xschop
                        • Feb 2006
                        • 1794
                        • oklahoma city
                        fork brace
                        here's the one I put on last year. It really does improve handling, and gives a more stable feel to the road...chop
                        MDRNF
                        79F.....Not Stock
                        • gnevelesx08
                          • Apr 2005
                          • 107
                          My tarozzi fork brace is basically the same design and mounting as the photo posted here by xschop except the joining brace bar is a solid piece. You can see that there could be some problems with drilling the hole all the way through. The clamp bolt heads are recessed and it would need machining a flat shoulder for the nut and washer to seat. May be possible, but once drilled and not work, I guess I would need alumiweld. I did see the web site for the alumiweld. These are all good ideas, I need to pick one to try or get off the pot (Toilet). Will post results
                          Thanks guys
                          Dan
