79 XS muffler alternatives
  • tab1324
    • 303
    • Brooklyn Park, MN
    I have heard and seen others using Harley Sportster mufflers on their XS. What year or size is the right one? Does it require a jetting change? Do they mount right up? How much do they run typically? I'd be looking for a used set - maybe they're available from local shops??
    Tom B.
  • Geezer
    • May 2003
    • 2985
    • Willamina, Oregon 97229
    I paid $20 for a pair of like new Sportster mufflers off eBay but I've heard that if you visit a Harley shop and tell them you're fixing up an old ratty Sportster, they'll give you a pair. On the other hand if you tell them that you're going to put them on a Japanese bike, be repaired to shell out some bux.
    I had a set of stock standard pipes on the Mongrel that were well rotted out and I cut them off leaving several inches of the old muffler. I then slit the bottom of the old muffler cone and rolled it down to fit the new mufflers so I wouldn't need a pipe adapter. After that it was a direct bolt up and no jetting change was required.
    I lost the crossover pipe so I may have also lost a little bottom end power but I haven't noticed it. They look good and sound great but not too loud.
    Geezer
    • webbcraft2150
      • Sep 2002
      • 1605
      • AUSTIN.TX
      I did not like the look of the Sportster mufflers so here is the fix I used on my 80g. You specified which model of 79 you have but the work would be the same, mufflers would be a different length.
      JC Whitney markets a buch of different mufflers. I purchased a pair of the "extra long" style for my standard G. At the time I purchased them they ran about $50 each. I cut the pipes just in front of the factory crossover. I purchase two adapters to bring the od of the factory pipes down to the id of the replacement mufflers. So far, so good. I slide the new mufflers on and eyeballed the rear mounting brackets. I was able to modify them with a little bending to allow the new mufflers to mount. Things you need to watch out for is clearance between the muffler and the axle bolt and room for the rear brake pedal to have enough travel. If you pick the shorter mufflers that stop before the axle bolt, things are a little easier. I did do a little grinding on the rear brake pedal to gain more clearance and be able to keep the pipe tucked close to the frame. Also had to fabricate a "stop" for the centerstand. This was all easier than it sounds. The JCW mufflers closely resemble stock in appearance. The initial exhaust note was a little raspy but now that I have a few thousand miles on them they sound fine. Soon as I figure out my digital camera and can pry the computer from my young lass, I will post pics.
      • GNEPIG
        • Apr 2005
        • 1657
        • fl
        .. i have used the sportster muffs before and i think they look pretty good. people usualy have there pig muffs replaced[for louder ones] within the first 500 miles, then they leave them at the cycle shops and the shops end up throwing them away. i suggest that you make sure that you get the sportster muffs and not the dyna muffs. the sport muffs have a welded tab sticking up from the back of them. the dyna muffs have a slide channel on the back side. i have taken these two different muffs apart and the sport muffs have more holes in the baffles then the dyna muffs, more holes = better flow. also you dont want muffs from an 03 or newer sport, they have cross over holes, unless you are up for adding a cross over pipe. you could score a set from ebay or your local pig shop for about 20 bucks.
        • tab1324
          • 303
          • Brooklyn Park, MN
          It sounds like there's some cutting involved in fitting the Sporty mufflers up?? Are there any options for just slipping into the the stock pipe? For $20 I guess you can't go wrong even if there's a bit of cutting involved. I'll have to track some down this weekend if I can't find a bolt on option. I don't think the mufflers on my bike are stock based on photos I've seen on this site. The brochures show a stock pipe with a "bevel" at the end - mine are flared out, not in... Make sense? What could mine be from?
          Tom B.
          • Geezer
            • May 2003
            • 2985
            The Harley mufflers are for a larger diameter pipe and if you don't leave a stub of the old muffler when you cut it off the factory pipe, you will need a pipe adapter.
            I don't know about the quality of JCW mufflers but the one time I ordered from them they charged my card several times and I had a bitch of a time sorting it all out. I won't buy from them again no matter how bad I want the part.
            Geezer
              The glass-pack types absolutely suck. I could not tune the carbs to get the big dead spot out of the mid range rpms... and I mean big.
              Geezer
              • webbcraft2150
                • Sep 2002
                • 1605
                • AUSTIN.TX
                Don't know about the grief you had with them billing you. I have not had a problem, yet. The mufflers I got were not glasspacks and to date are holding up well as far as finish and exhaust note. Did not have to frig with carbs after I put them on either. No bog or flat spots anywhere between idle and "oh ****". Maybe I just got lucky?
                • tab1324
                  • 303
                  • Brooklyn Park, MN
                  roadking mufflers
                  I've got a co-worker with the original roadking mufflers off of his bike I'm going to check out this weekend. I'll give a report of whether they'll fit up or not.
                  Tom B.
                  • XJ1100
                    • Apr 2006
                    • 33
                    • Duluth, MN
                    Sorry to dig up an older thread, but I guess it's better than starting a new one...
                    I'd like a bit "throatier" sound on my XJ1100. I'm considering HD fat boy pipes, unless of course someone wants to talk me out of it...
                    I'm getting a little confused doing the research as to where to cut, what adapter I'll need, and how to actually install these.
                    Anyone have any good pictures that can show an idiot like me how to do this? Will I need to mess with the carbs after they're installed?
                    Any help would be greatly appreciated.
                    • webbcraft2150
                      • Sep 2002
                      • 1605
                      • AUSTIN.TX
                      I don't know if the fat boy mufflers would give you a better exhaust note, but they may look out of place on your rig. As I mentioned before, check out the JCW or EMGO mufflers. Maybe you could attack your current mufflers with a drill? I recently drilled some extra holes in the end of my JCW mufflers and not only got a "deeper" exhaust note, my idle smoothed out and I swear it redlines faster.
                      • XJ1100
                        • Apr 2006
                        • 33
                        • Duluth, MN
                        Well, as a lot of people have said, I'm really nervous about getting pipes that are too loud. My neighbor has a HD and I cringe everytime he fires up and blasts down the road.
                        I like a thicker, throatier, deeper sound..but I don't want to be HD loud. So, having said that, what are the best options for my XJ1100? Keeping it simple of course...
                        • Geezer
                          • May 2003
                          • 2985
                          The stock pipes aren't Harley loud and that's why they're available dirt cheap. One of the first things Harly rider changes are the mufflers and sometmes the pipes too.
                          I have sportster mufflers on the Mongrel. It sounds nice and isn't clost to loud. I've taken it on a few longish trips and at high speed the wind is louder than the exhaust.
                          Geezer
                          • Poprock
                            • Apr 2005
                            • 594
                            • Oregon Coast
                            Sportster muffs
                            I got 'em off Ebay. Local exhaust shop installed them, made the adapters, got Harley muff clamps, and he welded up a bracket that fits the original mounting point perfectly. They work fine, no crossover is no problem. Compared to stock sound, it's about the same volume but a slightly lower pitch. I like the look OK, but I'm thinking about getting some of the shark fin long ones for my bagger. SWMBO thinks it sounds friendly.
                            • TomKat
                              • 63
                              • Lyman, IA
                              I just picked up a pair of Sportster muffs off of eBay for $9.99. Not quite new condition, but if I like them, I'll get better ones.
                              1979 XS1100 SF
                              Under Construction,
                              Due out by Spring '07
                              "Some days, it ain't even worth chewing through the restraints."
                              TomKat
