A K&N Mod for an XJ
  • MAXIMAN
    • Jan 2005
    • 1817
    • As far from the government as humanly possible.
    A K&N Mod for an XJ
    Everyone knows K&N made a filter for the XS air box. And...everyone knows they didn't make one for the XJ.
    Well since I'm doing a complete performance upgrade to Zilla I had to figure out a way to install a K&N filter without going to pods. I don't want pods on Zilla because it's my road bike. Occasionally on one of those 3000 mile road trips I'll get caught out in the rain. Besides I don't particularly care for the look of indivdual filters.
    This is a very simple modification. I took an OEM breather and cut the paper element out leaving the metal frame.
    Then I used a K&N "drop in" panel style filter that was very close to the dimensions of the OEM filter frame. The K&N number is 33-2586. I ordered direct from the K&N website.
    The width was exact. But the length was slightly long by about 1/4 to 3/8 inch. I cut it to length and used RTV to seal it in the frame. Then I used JB Weld to reassemble the frame cross-member to the frame.
    In theory it should allow the engine to breath more readily...but I can't prove that. If I feel like it I do an A-B dyno run while the bike is locked down on the rack to see if there is any difference between the two. I'm not betting it will be discernable but ya never know.
    Here's pics:
  • GNEPIG
    • Apr 2005
    • 1657
    • fl
    .. i'm betting you will be able to tell the difference.
    • MAXIMAN
      • Jan 2005
      • 1817
      I hope you're right. It went to a lot of trouble to build that filter.
      We'll see.
        • 7831
        Maximan,
        At least you only have to build it ONCE! After that, clean and go like the rest of us with the older filters.
        Ray
        • MAXIMAN
          • Jan 2005
          • 1817
          Well Ray the problem is I'm like GNEPIG. I'm actually crazy enough to think I could improve upon my own design.
          But I'll likely take your advice and quit right there.
            I have heard this discussed on here a couple times, and I just don't see it. I can't see anything actually getting in to the pod filters besides a light mist... maybe if they faced forward... but they don't. Engines actually run better with moist air.... moisture turns to steam in the cylinder.. expanding and actually improves compression ratio a little. I could see an actual ingestion of straight water, but I just can't see how a little water could hurt through a pod filter. By the time it makes it's way through the filtering material, it would just be injested in a mist. I know I ran mine through the car wash the other day, high presure EVERYTHING... even the pods.... busted right off afterwards. I may try misting them with the hose with it running and see if it does anything.
            Now that mine is up and running... I may just ride it in the rain! lol.
            • andnew
              • Apr 2006
              • 50
              • Enumclaw, WA
              From my past life playing with 4x4's they run K&N specifically because it won't allow large amounts of water through the filter when properly oiled. Especially when fording when a large ingestion of water would cause engine damage.
              My XJ lives outside with pods and we get plenty of rain here in the northwet. (In fact it's raining now). I've never had a problem with any water passing by the K&N's
              Andy Newell,
              Enumclaw, WA
              03 BMW K1200RSA (Dread Zeppelin)
              1996 Triumph Tiger
              • Dan Hodges
                Sensei of Internal Combustion
                • Sep 2004
                • 526
                • A garage in south St.Louis
                Re: A K&N Mod for an XJ
                Here's pics:
                I have never actually looked at the filter from an XJ before, but from these pictures it looks to have more surface area than the filter from an XS.I will be going to Yamaha to get both stock filters and compare them.A modified XJ air box on an XS 81 Special,interesting.
                • MAXIMAN
                  • Jan 2005
                  • 1817
                  Sorry if you don't see it bro. I have a friend in Ponca City htat put pods on his ZRX. He got cought out in a down pour and claimed his bike would barely run after being in it for about 30 minutes.
                  I don't want to take any chances of being "dead in the water." pun intended
                  The last thing I want is to be somewhere between Delta, UT and Fallon, NV...in the middle of nowhere and have a problem in a rain storm. I may be paranoid but so be it.
                  Secondly I simply do not like the look of the individual pods. Just a preference thing. I actualy prefer the look of the stock air box.
                  Stay tuned for one of the coolest mods you'll ever see for a XJ11 in a new thread. hehehehe...
