well I am back with another question... I am trying to bleed my back breaks... I can pump and pump and no pressure builds and when i open the bleeder I am still getting air even know fluid has been running clear for a while.....I took off the back line thats the reason why I am bleeding them ...they were working before...please help me out... Thanks
rear breaks bleeding
Tags: None
Is the line tight? Is there any chance you cracked the line when taking it off?
Describe how you are bleeding the caliper. I don't know your mechanical skill level, so maybe there is something in your bleeding method that is allowing air back in.Brian
remembering the same thing! -
I got it finally... I think the fluid got "worked up" a little because it got almost like a foam...I let it set and tried it again and it worked.. thanks a lot though... you all help keep me on the road..Comment
