Valves
  • n7qnc
    • 12
    • Waldport, OR
    Valves
    Does anyone know what the angles on the valve seat of an XS1100 should be?
    Thanks.
    David Abercrombie
    1979 XS1100SF
  • mro
    • Oct 2005
    • 4276
    • Hayward, California
    45%
    As per the valve, "service limit" above angle 0.7 mm
    bevel width bottom of valve stem 0.5 mm and stem end minimum lenth 4.0 mm
    max valve stem clearance intake 0.10 mm, exhaust 0.12 mm
    will need to check dia of valve stem and of valve guide to find if still in spec.
    mro
      " The valve seat is subject to severe wear. Whenever the valve is replaced or the valve face is re-surfaced, the valve seat must be re-surfaced at a 45 degree angle. If a new valve guide has been installed, the valve seat must be re-cut to guarantee complete sealing between the valve seat and the face. If cutting section "A" of the valve seat, use 30 degree cutter. If cutting section "B" use the 45 degree cutter. If cutting section "C" use the 60 degree cutter."
      As plagiarised from my book.... lol.
      • n7qnc
        • 12
        • Waldport, OR
        Thanks for the information. This will help me a lot.
        David Abercrombie
        1979 XS1100SF
        • mro
          • Oct 2005
          • 4276
          ya, what trbig said
          seat width 1.3 mm (standard) 2.0 mm wear limit
          (surface contact width between valve and seat, 45% part)
          mro
          hey trbig, ya got a scanner???
          cool posting images too.
            Nope... just a digital camera I use as one on occasion!
