I need someone with a torque wrench to remove their spark plugs and tell me what amount of torque (ft/lbs) is required to turn the engine over. I know this can vary but I just need a ballpark. As I'm putting my engine back together, it seems like I have a bad primary shaft (dampener cam) but I cannot be sure. I talked about this in another thread but I thought knowing the torque of the engine drag might help others diagnosing stuff as well.
Tom b.
Tom b.
Regrettably it took less than 10 lbs of torque to rotate it! I know you were getting much higher values than that!
This was on an engine that had been parked for quite a while, I had only put in some MMO down the spark plug holes months ago, it wasn't frozen, but I knew I wouldn't be working on it for a while.
