My 82 Xj1100J Maxim is in refurbishing faze. Trying to check all that may have gone bad while it was setup in a container. Oil, filter, air cleaner, battery, tires, fuse cleaning, connectors cleaned, drive has new grease and oil, so many things, then I removed the rear shocks to wire buff the aluminum housings only to spill oil from them. I don't know how much or what kind to use in replacement. I don't have a repair manual yet. Another problem is the rear brake pads are worn at an angle. It seams that the caliper is canted and can't find anything bent. Is this normal or not? Also the rubber bushing attached to the frame stud is broken, New one anybody. HELP!!
Dell82
Dell82
