Hi can anybody tell me if your crank is knackered ,can you simply put a different one in from another engine??
I have heard in the past that the crank and engine cases were machined to fit each other on the production line so you won't be able to just swap for another crank ??
Also if you can fit a different crank is there a difference between years models ??
Thanx
Gaffer
Thanx
Gaffer
and you are able to determine what size bearings you need to get the NEW shaft to match/fit with the OLD Cases!
