how do you take the reflectors off an f headlight
  • mason79
    • Mar 2006
    • 1359
    • los angeles, ca
    time to install the fairing i bought from planedick, and i don't want to butcher the headlight ears, i'm sure one of youz, had dunnit before, please assist thanks!
    History
    85 Yamaha FJ 1100
    79 yamaha xs1100f
    03 honda cbr 600 f4
    91 yamaha fzr 600
    84 yamaha fj 1100
    82 yamaha seca 750
    87 yamaha fazer
    86 yamaha maxim x
    82 yamaha vision
    78 yamaha rd 400
  • xswilly
    • Jul 2003
    • 462
    • Hollis, maine
    you need to remove the lens assembly
    two screws at the bottom of the chrome around the headlight
    then inside the headlight housing there is a nut on the inside of the reflector, take the nut off and the reflector will come off
    "BUT" that is also what holds the headlight houseing to the headlight ears,
    i guess you can replace them with bolts
    http://home.securespeed.us/~xswilly/
    79F Parts
    80G Parts
    75 DT 400B enduro
      • 7830
      If you are putting on a frame mount fairing, you will remove the headlight bucket anyway. You may also have to remove the "ears", if they cannot rotate out of the way. To do that, put the bike on the center stand, lift up the frame at the front of the engine, and loosen all the pinch bolts on the triple trees. The forks will slide down, and you should be able to remove the ears, lower the front end of the bike to slide the forks back up(you DID use a jack on the front?) and tighten up the pinch bolts once again.
      Ray
      • John
        • 5117
        I dunno Ray, that's a lot of lifting to get the ears off the fork tubes. I had to use a tall clothes line support to throw a rope over to lift one high enough. Removing the upper triple clamp would be easier.
        • mason79
          • Mar 2006
          • 1359
          • los angeles, ca
          i've seen then rotate and i've seen them with the bucket still on but thanks for the info gents
          History
          85 Yamaha FJ 1100
          79 yamaha xs1100f
          03 honda cbr 600 f4
          91 yamaha fzr 600
          84 yamaha fj 1100
          82 yamaha seca 750
          87 yamaha fazer
          86 yamaha maxim x
          82 yamaha vision
          78 yamaha rd 400
