andreas - kickstarter needed
  • tab1324
    • 303
    • Brooklyn Park, MN
    Andreas - I want to add the kickstarter to my XJ1100. Do you have all the components I would need? The cover has the hole for the kickstarter shaft already so I would just need the internals and the kickstarter arm.
    Thanks,
    Tom B.
  • 50gary
    • Apr 2006
    • 225
    • Saginaw, Michigan. USA Third stone from the sun
    I also want to run a kick starter. My '78 standard has one but my question is does an XS850 folding lever work on the XS11?
    Cheers, 50gary
    • mason79
      • Mar 2006
      • 1359
      • los angeles, ca
      bought a xs750 kick start lever and it did not work, spline count was good except the pinch bolt, would have to run thru the shaft splines, you could grind it down, but i don't know about that, the starter is working fine for now and besides i have the non folding lever tucked away...
      i think the 850 and the 750 are the same
      History
      85 Yamaha FJ 1100
      79 yamaha xs1100f
      03 honda cbr 600 f4
      91 yamaha fzr 600
      84 yamaha fj 1100
      82 yamaha seca 750
      87 yamaha fazer
      86 yamaha maxim x
      82 yamaha vision
      78 yamaha rd 400
        xs650mike has a folding kick lever on his machine. I forgot what he "borrowed" it from, but it is the folding lever.
        You may be able to do a search on kick start, and find the answer.
        Ray
